Question about Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge problem with draws.
Hi, I do hope you can help me with this problem.
My Hotpoint FFS70 fridge freezer section no longer closes when the draws are in place, when i remove them it closes fine, it does not have a build up of frost in side that i can see. It seems like the back of the freezer has come forward ( i have never moved the fridge ) and now the interior doors no longer enable the door to close.....Help !!!
  • Anonymous Apr 28, 2009
    I have the exact same problem with the draws in my hotpoint Fridge Freezer
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Posted on Nov 29, 2008
Hi my freezer door on FFA70 Hotpoint isn't closing. I have taken the draws out and defrosted it. The door closes when none of the draws are in, but doesn't when the draws are placed in their...
Hi, I had exactly the same problem and eventually realised that the panel at the back of the freezer was coming loose. When I removed it I found that all the parts behind the panel were covered in ice, a lot of ice! So I have defrosted this ice using bowls of steaming water (not sure if this is an appropriate way to defrost, but it worked fine for me), I have also read you can use a hair dryer to spead up the process - apparently if you try and chip the ice off it can damage the parts in your freezer. I have now fixed the panel back on the freezer and it is working like new and I have had this fridge freezer for years now.
Aug 02, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ihave recently moved my fridge freezer ,and the red alert light has come on,could you tell me what is wrong,thanks
It comes on when there has been a power interuption to warn of a possible thaw of food or that the inside temp was high, it will correct itself within 24 hours or you can push the reset button beside the light to cancel.Please let me know if this works
Jan 19, 2011 | Hotpoint FFS70 Bottom Freezer Refrigerator
Freezer temperature light permanently on, indise fridge & freezer temps seem ok however the ouside wall & section between fridge/freezer is hot to touch. Have checked ice build up & removed in...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 25, 2010 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Hotpoint FFS70S fridge drain pipe blocks with FROST in a few days after clearing. I suspect that the drian pipe is too close to the freezer compartment. Is this a common problem. More to the point, is...
I have the same problem. Engineer said most likely problem with insulation and since pipe is moulded onto the back, it cannot be fixed easily. Defrosting is a temporary solution only. Luckily I kept extended warranty going, they are going to replace it with a new one.
May 17, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Oct 30, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint FFS70 Bottom Freezer Refrigerator Logo
273 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
