Question about Frigidaire FGF316 Gas Kitchen Range
Oven won't light
My frigidaire FGF 316 oven will not light.The ignitor seem o.k.,it really gets hot! I installed a new safety gas valve and it lit only one time.What is my next stept. I already spent $140.00 on the safety valve!
Thanks,Greg
  • 116 Answers
Tip - do not change the safety valve first even if the ignitor seem "ok" if you gently tap the safety valve and the flame comes on initially but fails to come on after awhile after each"tapping" - the ignitor is the most likely culprit
Posted on Sep 04, 2008
I have a Frigidaire model FGFL87DCE gas range and the oven will not work. It doesn't light and the gas doesn't come on
the first thing to check is the ignitor.turn the oven on and look to see if the ignitor is getting hot if it not you will need to check the power to the ignitor.if there is power to it then you may neeed to replace the ignitor.
If the ignitir is not drawing enough current then it will not open the gas safety valve
Dec 11, 2010 | Frigidaire Ovens
Oven won't start
Very interesting. The ignitor is working, so that means you have power and the control is working. The safety valve is working, and you have a complete circuit. So why won' t she fire off? Inside the safety valve is a bi-metal that only opens if the resistance is right. The resistance only changes when the ignitor is on. As it gets hotter it changes in resistance. This allows the gas safety valve to release the gas and ignite. Watch this:
May 07, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Oven burner will not light. Ignitor is orange hot.
When ignitor gets worn it will come on but not get hot enough to open the gas valve. Very rarely the valve fails.
Part number 5303935066
May 20, 2009 | Frigidaire FGF334BG Kitchen Range
Gas oven does not get hot enough
You probably have a bad ignitor. Oftentimes the ignitor lights but doesn't draw the proper amps (3.2) to open the safety valve. If you have an amp probe you can test that.
Apr 07, 2009 | Ovens
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Hello, I have a Frigidaire Range stove Model #FGF378WCCD. The oven ignitor heats but the oven doesn't light up and we smell no gas. What can it be?
if the ignitor may glow but if it isn't turning almost white it is not getting hot enough to open valve ,,,,, make sure it glows very bright and if not replace it / larry
Nov 29, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Oven won't work
This could be a defective ignitor (glow bar) or gas valve (safety valve). If you gently tap the safety valve and it lights up very likely ingnitor problem
Regards
Jul 26, 2008 | Frigidaire FGF316 Gas Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Frigidaire FGF316 Gas Kitchen Range Logo
462 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
