Question about Goodmans Televison & Video
I have in car dvd 7inch screens no gce4000ps2 i need to get anew power lead as i plugged the lead into a 24 v socket by mistake i changed the fuse but nothin happened. nothin was connected to the lead
  • 33 Answers
The manufacturer will have a parts division that can supply you with these.
Posted on Jun 12, 2008
No channels on the portable tv player
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | Philips 7inch Portable Hdtv Tft Dvd Cd...
Changed plugs on a 1999 f-150 engine now I have a engine miss
check you dont have a broken lead removing them one at a time with engine running will show you which cyl is not firing check plug wasnt cracked when being fitted change lead double check firing order if the engine didnt miss before the plugs were changed then this course of action should fix the miss its easy to cracl spark plugs when fitting if the plug socket does not have rubber insert carbon leads only need to be pulled to hard or bent to far to damage the carbon fibers that run through them check that you dont have two leads crossed this is a common mistake with v8sand is easy to do
Apr 06, 2011 | 1999 Ford F150 Regular Cab
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
No light on Motherboard Asus P3B-F
if yo have no light on the motherbaord this means that the PSU (Power Supply Unit) is either faulty (so no delivering 5v to the motherbaord) or is not plugged in properly in order
1. does something else that works somewhere else work in the plug you are using for your PC (yes goto 2 No you need an electrician to look at you mains sockets)
2. Does PSU have an independent Power Switch is it ON
3. Unplug and plug back in you power leads. (does it work OK if not goto 4)
4. Does the power light come on your VDU if yes swap the power leads from VDU to PC (does PC power up and screen dead if yes replase fuse in Plug - like for like - if no goto 5)
5. Problem is most likely with PSU replace unit for another one the same - be sure to get the same number of ATX connectors you can get a 20 and a 24 pin variant
Jun 28, 2009 | ASUS P3B-F Motherboard for Slot 1 CPU
Cigarette lighter won't work
The front lighter is powered by fuse 24 in the interior fuse panel and the console power points are fuse 7 and 9 in the battery junction box under hood.
If you have a 12V test lamp you can check the socket for power and check the wire to the socket.The socket may be bad.
Apr 08, 2009 | 2005 Mercury Mountaineer
BMW X5 06 - DVD wiring problem
Every car and every stereo has a different plug and socket arrangement. Your best bet is to google search Car Audio in your area, and get a shop to take a look. They will be able to source the exact adaptor you need, with no mistakes...
Hope this helps,
M3ODQ
Jan 31, 2009 | BMW 02+ 3 5 X5 M3 Series Car Radio Wiring...
Dvd works great ,need to replace power socket ear phone socket
sorry my mistake, I was trying to find afree service diagram to help me change a worn power socket in grandson`s cyberhome portable dvd model ch-ldv 700b. Thanks
Jul 15, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
PYLE PLDF7IN
CHECK TO MAKE SURE THE INLINE FUSES ON RADIO ARENT BLOWN .
YOU CAN CONNECT POWER TO THE POWER OUT LEAD AND MAKE IT COME ON
Jan 17, 2008 | Pyle PLDF7IN Car DVD Player
No Indication...Dead Unit?
Firstly, try plugging the unit into another mains socket just to make sure it's not the socket that's faulty, or try another appliance in the socket you are using. Next, make sure the fuse in the plug hasn't blown. If you don't have a fuse tester, you can try the fuse in another similar appliance to see if it works. If it has blown and your spare lead is the same, there will be an internal problem. Inside the unit is an in-line 2 amp fuse. If this has blown you almost certainly have a power board problem. Always switch the mains off before plugging in or removing the mains lead from the rear of the unit. Back EMF can damage the appliance if you don't do this.
Dec 26, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
48 people viewed this question
Top Goodmans Televison & Video Experts
olayoju victor
Colin Stickland
Colin Stickland
Steven Wander
Steven Wander
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
