Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
My sidekick seems to have a problem that I can't figure out. I charge it in the night and wiggle the cord until it can stay. It cuts off from time to time but when its time for me to use it it shows 4 bars on the battery for the whole day. But when its about to die it goes down to 3 bars and takes 10 minutes after to die, and if I let it die it restarts itself over and over until it's completely dead. But I don't know what's the problem, can somebody help me?
    President:
  • 625 Answers
It's the battery going bad. The issue you are seeing is caused by the battery meter not being calibrated.
You can get a new one from ebay for about 10 dollars.
Sidekick 3 Battery for Sale
Use the tips below from http://www.repairmysidekick.org/Improve-Sidekick-Battery-Life to train the new battery
This trick really only works within the first week of use. If you've used the device for 2 months already, this won't help as much (but it'll still help). Keep in mind, when I say "train the battery," I mean RECALIBRATING THE BATTERY METER:
A) I cannot stress enough that the initial charge out the box is crucial. Instructions state you should charge the device 6-8 hours upon initial start up. Most people are so geeked by getting the device that they yank it off the charger 3-4 hours later so they can go out and floss their sidekick. HUGE mistake. Despite evey urge to do so, let it charge at least 6 hours out the box.
B) Now, for the next couple of days try and let your device totally drain out it's battery before you charge it again. I've had a couple nights where I come back from work with the device already dead (Sucks for my commute, but well worth it in the long run). When you finally do plug it in, make sure it charges 4-5 hours minimum before you remove it. I usually leave them plugged in overnight...
C) You'll begin to notice an improvement in your battery life. Your device now has new "baselines" for when it's full and when it's not. Keep it up for another day or so (but don't waste an entire week doing it) and then you're set. Sometimes I would bypass the old automatic cutoff for charging by charging it while off just to make sure I "topped it off" (NOT reccomended for consistent charging, tho').
So that's what I did, and have done for every SK device since the CSK. My replacement now lasts me 18+ hours with heavy browsing, IMing, texting, and 1.5 hours of MP3 usage(commute). By the time I walk in my door, I usually have 1 bar left or the battery warning (which now lasts me about 30 minutes)...
Many have said I'm lying, and that it's impossible to "train" a lithium ion battery, but if you are consistant out the box, you can definitely recalibrate the battery meter to peak accuracy... Heck, my old SK2 used to last me 2 days solid (at least) between charges.
Other tips for conserving battery life:
1) Turn your brightness down as low as you can tolerate.
2) Try and avoid being on all 3 IM clients at the same time for any extended period.
3) If you use SMS-driven services like Upoc & Twitter, know when to ".off"
4) Music Player is 2nd only to phone calls in terms of being the biggest battery drainer. If you use the Music Player for 2+ hrs, you might want to consider and Ipod and an SKID.
5) Make sure that you clear out of the photo app completely, especially if you just took a picture. If you just "Jump" out, the device still keeps the camera rolling, adding more battery drain. Make sure you "Done" out of the camera app to be safe...
6) Make sure you try and keep the battery as cool as possible. The hotter the battery is over time, the less use you will be able to get out of it. Try to charge the device on something that displaces heat (like a table or desk) rather than something that'll absorb it (like a pillow/bed) for maximum efficiency... (Thanks, scenekick!)
Posted on Jun 16, 2008
  • 62 Answers
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Posted on Jun 12, 2008
I turned off my sidekick lx 2009 (off button) and it wont turn on
what i did was take out my sim charg it den cut it on it will cut on put sim bak in afta u cut it off and try again do a couple of time it will work
May 04, 2010 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick not charging
do you mean like the orange light is not light up when
it were charging, correct? if so, then you need to get a new charger.
your charger is probably dead and no longer working.
if you want ,i have a brand new charger that i do not need(bec, i have
few of them laid around and need to get rid of it) and will selling
it for pretty cheap.
so let me know.
Jul 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 won't turn on,it's plugged in but nothing's happening
I think you are going to need to call T-Mobile, and have them troubleshoot it, or take it in, and see if they can figure it out. Make sure the battery is in all the way, and its fully charged. Other than that I dont know. Good luck hope this helps.
Jan 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Can get it to chanrge (this is brand new)
remove the back cover and make sure the battery is inserted properly
Jan 10, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Jake-
That is the right button. The charging port is probably bad. This is a common occurence on sidekick 3's. Does the orange light come on but it nevers seems like it is charging?
The best thing to do is get a edocking cradle that has an external battery charger. It will allow you charge the battery seperate form the phone.
See link below
http://fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Sep 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
jazz im a tech at repairmysidekick.com sound like you cpu is frozen visit my website and we will fix it for you.
Dec 18, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Chargingb the phone
If it is a single pin charger that just plugs into the phone it sounds like the pin inside the phone has broken from the board which is why you have to wriggle it or wrap it up to get it to work.
this can be repaired but costs are determined by your repairer.
Nov 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Sound problem
what model is this? the very first thing i would do is make very sure you dont have a speaker wire shorting out on metal/rubbing/2 wires touchung togther somewhere. this is very bad. If this is a vrx935 id also try wiggling the "din" cord (its a blue cord with about 20 wires inside) between the brain and thwe head unit with the cd playing.. if the audio cuts in/out while wiggling that cord youve found your problem. If you cant figure it out and get sick of it i do buy old clarion dvd players for parts id love it for parts. let me know how it goes! mike bigmikeselectronic@comcast.net
Dec 25, 2006 | Clarion VRX935VD Car DVD Player
T-Mobile Sidekick® 3 Cellular Phone Logo
563 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
