Carrier Air Conditioner/Model # 38TG030300
Yesterday it was only putting out faintly cool air. I turned the unit off, hosed it out, changed fuses and turned it back on. It worked perfect, until now.
It started to do the same thing so I turned it off and checked the fuses, searched for any loose wires.... I'm lost. Now the fan kicks on and off but the unit itself doesn't seem to be kicking in.
  • 54 Answers
Hmm It's passable that the condenser fan motor is not spinning at speed or is running for a period of time and over heating and the Condenser fan motors internal overload protection trips and takes it of line shortly thereafter, of course, the compressor internal overload trips and takes it of line. Spraying with the water hose sped up the cool down on the internal overloads but I'm afraid it probably didn't do much to help the original problem. You could try replacing the Fan condensing motor capacitor-(it's listed on the side of the motor if the capacitor cant be read) and oiling the motor if it has oil ports (2 small plugs located along the perimeter of each end of the motor). If the motor can be oiled and you replace the capacitor theres a fair chance you might get by another year without replacing the condenser fan motor. Charged capacitors pack a nasty jolt so be careful, hope this was helpful, GL!
P.S. If it is the cond. fan motor and you replace it be sure you get a sealed outdoor rated cond. fan motor and the appropriate rain guards are installed.
Posted on Jun 12, 2008
Carrier model 38cks air conditioner compressor fan
sounds like you need to replace the condenser fan motor. It has a thermal overload inside the compressor and will shut it off before it harms the compressor. The only way to get it to reset is cool down the compressor with a water hose.
Sep 04, 2014 | Heating & Cooling
No manual for a cool 438656
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
Jan 05, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
The outside unit of my Carrier Air Conditioner/Model # 38TG030300 is freezing up the line going to the unit inside.
Is it freezing up at a drier or just a section of tubing? More info would be good. If the line is frosting up all the way back from the indoor to the out door coil, and I guess that we are talking about the suction line, the larger of the two. My guess it either the stat. is set to low below 72 degrees and or the indoor coil is dirty or the filter is. Clean the indoor coil be careful to not get water else where such as into the furnace take appropriate steps to prevent it. All AC units have to have 400 cfm of air flow for each ton of cooling if the do not have this they will freeze up, vents closed off will do the same as a dirty coil.
Jul 02, 2011 | Heating & Cooling
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
I have a Carrier 38CKB048 and it runs without shutting off.
99.9% probability that your contactor is stuck/sticking. Replace the contactor.
Apr 27, 2010 | Carrier 38CKC024 Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Apr 14, 2009 | Carrier 38CKC042 Air Conditioner
Outside unit not working
Make sure you are competent to work on this type of appliance. Do you have a electrical meter? Check fuses out side and get back to me
Aug 11, 2008 | Carrier 38CKC060 Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
1,137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
