Question about LG WM-1832C Front Load Washer
The washing machine drum will not turn / wash then the LE light comes on
  • poie Jun 12, 2008
    thank you for your help .the washing machine is a
    LGwm1832cw Direct Drive System Tromm
    I hope you can solve this problem
    Thank you poie
  • poie Jun 13, 2008
    HI mike.
    This is poie my washer is now working you were
    very helpful thank you.
    Poie.
MOST DIRECT DRIVE WASHER HAVE A COUPLER BETWEEN THE MOTOR AND THE TRANS. CHECK THAT FIRST,AND ALSO SOMETIMES THE LIP SWITCH GOES BAD FROM CLOSING TO HARD CHECK THAT ALSO,LET ME KNOW-MIKE
Posted on Jun 13, 2008
    Genius:
  • 1,122 Answers
Your washer belt might have broke or your motor control board could be bad,what kind of washer?let me know and we can take this farther-mike
Posted on Jun 12, 2008
  • MIKE major Jun 13, 2008
    please leave me good feedback,thanks-mike
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jun 29, 2011 | LG Washing Machines
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
LE errorMashine get only a litle water and the motor make a noise and after this its coming a L E on the display
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Sep 10, 2010 | LG WM0642H
I keep getting a code le why?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
My LG tromm washer keeps saying LE and no matter what I put in there it continues to say this
Check whether a large load size been used with a gentle wash setting?
Check whether the washer been overloaded
Thank You
Sep 04, 2010 | Washing Machines
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine keeps shutting off and has the letters LE in the display. What's going on?
It could also mean the hall sensor is defective and will need to be replaced.
Feb 12, 2010 | Washing Machines
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
LG WM-1832C Front Load Washer Logo
112 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
