Question about HP Office Equipment & Supplies
We have just purchased a photosmart d5360 printer & the photos when printed are red! its brand new so we shouldnt have to change any settings should we?
    Problem Solver:
  • 12 Answers
You could have one or more bad ink cartridges. Run some cleaning operations on the printer and see if all the colors look good when it prints them all out individually. That would help to rule out the ink cartridge/s. If that test reveals good color from each cartridge, then it must be some settings that need changed. I'm not an expert, but I've installed my fair share...
Hope this helps!
Posted on Jun 12, 2008
Does not print red on regular copy paper Does print red on 4 x 6 photo paper
Check ur printer settings. Might be set to print on photo paper.change settings to normal paper. If all else fails. Uninstall and reinstal printer software.
Nov 01, 2011 | HP Photosmart 3210 Printer
I have hp photosmart D5363 printer i change my pc now I can't print because I lost software cd
You can easily download the driver for your HP Photosmart D5360 from HERE.
I hope I helped!
May 23, 2011 | HP Photosmart D5360 InkJet Printer
I have a new mini dell laptop and i want to set up my printer which is a hp photosmart D5360 but i dont know how to ? i need help
you can find all related support for this product on the following link ,,,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3194503
depending on selction you will make it will give you the best solution ...
Dec 29, 2010 | HP Photosmart D5360 Printer
I WANT TO PRINT LABELS ON A HP PHOTOSHOP D5360
You may want to check the ensuite software that came with the printer, and see if it offers label printing. More likely, you can access label printing templates in Microsoft Office or Works, perhaps even Openoffice.org's freeware.
Oct 22, 2009 | HP Photosmart D5360 InkJet Printer
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
D5360 printing is smudged
Easiest thing to do before anything major is to open the properties of your print driver and run the head cleaning/alignment tool to make sure everything is working properly. Right click printer in printers folder and click properties. Tabs across the top and on of them should be maintanence or diagnostics. Under there is cleaning and alignment tools. Also sometimes it is located under your program files directory under hp printer model.
Hope that helps,
TankMurdock
Apr 24, 2009 | HP Photosmart D5360 Printer
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Feb 05, 2009 | HP Photosmart D5360 InkJet Printer
HP D5360
Have you tried running the head cleaning in the maintenance section of your print driver? If the lines are clogged it will not print anything, also if ctg has just been changed make sure all packing has been removed. lots of times there is clear tape covering the bottom of ctg so it doesn't dry out when in package. Running the cleaning tool a few times forces in thru the lines and the print head. Usually under the properties of driver, (right click driver and select properties) then find maintanence tab.
Hope that helps
TankMurdock
Dec 09, 2008 | HP Photosmart D5360 Printer
Seeker5211
Seeker5211
