Question about Sony Ericsson P990i Smartphone
How do i remove the flip on my se p990i? - Sony Ericsson P990i Smartphone
  • Anonymous Sep 07, 2008
  • Anonymous Sep 11, 2008
    How to remove the flip of P990i
    Problem Solver:
  • 8 Answers
Switch the phone off, look at the back of it, remove the back cover, remove the battery. you should see two copper colored screws, remove the screw, remove the flip, replace the flip with the small cover that you should have recieved with the phone, replace the screws, replace the battery, replace the back cover, switch the phone on and operate as normal but without the flip. A hint though, you touchscreen will get dirty very quickly
Posted on Sep 22, 2008
Removing the flip,in p990i
Posted on May 12, 2010
  • bullygram May 12, 2010
    1:WHEN U REMOVE THE BACK COVER WE CAN SEE THE SCREW
    2:TURN THE PHONE FRONT SIDE AND REMOVE THE FLIP(HANDLE WITH CARE)
    3:U GET THE FRONT BOTTOM COVERING PART WITH THE PHONE.
    4:ND WE R DONE !
Were i can found the one that will replace on the flip?
Posted on Aug 10, 2011
2 Suggested Answers
Gsmfather
  • 113 Answers
SOURCE: i have a SE p990i
you dont need to press "c" button on p990i instead there is @ sign button which you have to press while connecting your phone to usb.
Posted on Dec 03, 2010
My p990i phone the fip is broken and it is remained as if the flip is closed and i cannot use the other functions.......how can i flip open if the flip is broken.....
You need to dismantle the back panel and unscrewing 6 screw using a T6 precision screw driver to be able to release the front panel,but be careful cause the keypad flex connector is attach on the board interface and be careful cause touchscreen and LCD is also connected. On the upper panel,remove the keypad panel by inserting a flat screw driver on each side at the bottom of the front panel.if done,remove the adhesive at the back of the keypad interface and you will see the keypad flex connector,if the parts is still ok,gently remove the flex cause it is fitted by a strong adhesive.the you can replace or if not put an adhesive on a broken part.
good luck....
Jun 20, 2011 | Sony Ericsson P990i Cell Phone
I have a sony ericsson p990i with following (EMEI:35870030015682, EMEISV:78, EMEI:135790246811220). This phone hangs so much, and also it scrolls so fast even if you've not touched anything and lastly it...
You can do this by entering the Service Menu and selecting Format. Here is how to get there:
  1. In flip closed mode: jog-dial up, *, down, down, *, down, * -
  2. In flip open/removed mode: In phone application, jog-dial up, touch *, down, down, *, down, * .
Apr 26, 2011 | Sony Ericsson P990i Cellular Phone
How to physically flash sonyericsson p990i or any other way to flash the phone
my question is i am flash our Sony Ericsson P990i but my my cell phone lot of time restart again and again what i can do
Feb 06, 2011 | Sony Ericsson P990i Cell Phone
I have a SE p990i i want to a software update in it but i have no flip n C button what can i do now plzzzzzzzzzz tell me???
Dec 03, 2010 | Sony Ericsson P990i Smartphone
My p990i flip keyboard 123 numeric and navigation key not working how to solve this problem also touch screen not working
My p990i flip keyboard 123 numeric and navigation keys not working.
How can I solve this problem?
Nov 10, 2010 | Sony Ericsson P990i Smartphone
Hello, I am unable to use the update service for p990i
very simple solution press the "c" key on the qwerty key pad - Which i tried it works
Apr 11, 2010 | Sony Ericsson P990i Cellular Phone
My se p990i flip keypad malfunction
It has a flex/ribbon inside the flip keypad,you must replace it or the whole flip k-pad.
Jul 22, 2009 | Sony Cell Phones
Flip keypad problem
i have p990i smart phone but now its flip keypad is not working its 1,2,3, and main menu swith are workin .now what i do ??? please give me the sugestion
Mar 23, 2009 | Sony Ericsson P990i Smartphone
Sony Ericsson P990i Flip keyboard not working
Hi.
I had the same problem with my p990i. I stripped the flipped down and inspected the microswitch which gets activated when the flip is closed. The mountings and actuators get worne out after prolonged use. I cleaned everything out and reseated the switch correctly. Worked fine after that. If you do not have a bit of technical experience, i don't suggest you do it yourself. The ribbon cable is very easy to break.
Hope this helps
Sep 20, 2008 | Sony Ericsson P990i Smartphone
Sony Ericsson P990i Smartphone Logo
2,496 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
