Question about Nokia 5200 Cellular Phone
Reinstall Firmware how can i format the entire firmware and reinstall everything once again.Because the menu,selection,end buttons are`nt working,but the number keys are working.
  • Anonymous Jul 26, 2008
    no puedo instalarle el firmware
  • yletta Aug 14, 2008
    quando entro nel menu si spegne il telefono
    Brigadier General:
  • 7,752 Answers
You will need to take the phone to a mobile service center and have them reflash the phone for you.
Posted on Aug 26, 2008
Sir! i have samsung YP-U2 ipod *** pendrive. I have just formate this. now no song are playing in it. What can i do Plese tell me!!!!
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP01&searchWord=YpU2&searchInputBox=Yp-U2&find_button=
Go to this site ...select the exact model of your YP-U2 ...cause there are about 3 different series..and when you know for sure your model ...select it from the tab ...Than select firmware ..and download the firmware software ..connect the device by the cable ..and reinstall the firmware into the unit..
This should bring it back if you formatted it from the computer and delete the firmware ..
If the firmware is not deleted...that just reconnect it to the computer and look for it into My computer folder...You should see it like a removable device ...open the folder and copy into it files with music (mp3 files) ...after that will have the music in it again ..
Jul 31, 2010 | Samsung Audio Players & Recorders
Computer won't read mp3 player
I am going to assume that you have read my FAQ on Sansa players. If not, I will reprint it below. I had one in particular with which all of the below methods had failed - I simply plugged it into another computer - other than the original, and presto! it came back to life again!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 03, 2008 | SanDisk Sansa Clip MP3 Player
E200
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 20, 2008 | SanDisk Sansa e260 MP3 Player
PLEASE HELP ME
-Tha Mp3 Doctor
Stuck in language mode
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk keeps skipping/freezing songs!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 player
Get firmware upgrade - it will reinstall the correct format
-Tha Mp3 Doctor
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260: Firmware download problem
or
-Tha Mp3 Doctor
Dec 22, 2007 | SanDisk Sansa e260 MP3 Player
Help!!
upload the firmware again
Apr 13, 2007 | Olympus m:robe MR-100 Digital Media Player
Firmware not reloading
Take out the battery, press and hold the ON switch and reinsert the battery. Hold the ON switch until the recovery menu appears shortly after the Creative Logo disappears. Selection option 3, which is to reload the firmware. Keep in mind that doing so will delete everything on the player.
Oct 19, 2006 | Creative Labs Zen Micro MP3 Player
Nokia 5200 Cellular Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
