Question about MSI MS-6734-10 (-6734-010) Motherboard
PC will not start up
Hi
my PC will not start up there is no sign of life at all. am using XP. I have changed the power supply unit, checked all connection to the motherboard and still no luck.
many thanks martin
    Genius:
  • 1,019 Answers
Hi Martin,
you could have one or more faults here.
first i,d suggest double-checking the connections from case to motherboard. power/reset/hdd led et,c.
next would be to test the power supply unit, if the old or swapped power-supply-unit is compatable with the motherboard.
this will eliminate the psu.
remove any external devices such as printer or usb devices.
it,s always best to go back to bare minimums, when fault finding. these can always be added later on.
ensure the power connectors are correct to hard-drives/dvd drives et,c. Finally is the motherboard itself. Is it Brand-New or Secondhand ? and if you replaced it. are the casing spacers installed correctly ? ( Brass nuts that seperate the motherboard from casing ) if any of these are in the wrong place, you can have an earthing problem. or a dropped screw under the motherboard. it,s all a process of eliminating faulty components/devices. i,d backtrack first, then test out individual components on another computer.
Mike @ Compurepair.
Posted on Jun 12, 2008
    Problem Solver:
  • 27 Answers
Greetings...
With the power off and plug disconnected from the computer, GENTLEY, remove video card and reseat, and reseat the memory chips... be very careful... also, find the reset jumper and reset the motherboard to default factory...
Here is set of detailed instuctions that could be helpful...
Did you just have a storm, power outage in the area? Do you have a UPS protecting your system?
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Computer won't boot - fan on cpu does not run - cd drive does not power up -
Hi.
If there is no sign of life, then it is usually a power supply problem. Check PSU connector. If PSU fan does not turn on check the power cable. If power cable is good, test power from PSU using a multimeter and eventually replace PSU.
Dec 03, 2010 | E-Machines eMachines Refurbished EMA...
Smart2200RMXL2U shows no sign of life after storage
These units, while hot swappable, will NOT start with dead batteries connected.
You will have to replace the batteries to confirm if the unit is still usable. Sealed Lead Acid Batteries do have a shelf life when a charge is not applied and will fail after several months of sitting around.
If your unit was working fine before it was put in storage, I definitely would consider just replacing the batteries. It is possible that the batteries are connected loosely, you can try opening the unit up to double check all the connections but if it has been sitting for more than a couple months, I would definitely consider the batteries dead.
You can find replacement batteries here http://www.refurbups.com/Tripplite-SMART2200RMXL2U-Batteries
Apr 02, 2010 | Tripp Lite Smart Pro UPS System
Polycom Fx doesn't power on or show any signs of life
Try disconnecting the ISDN module and then cycling the power. If that doesn't work speak to your support provider about repair costs. Ultimately you may need to replace it because of its age (it might be End of Life and not available for repair)
Sep 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
MSI MS-6734-10 (-6734-010) Motherboard Logo
165 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
