Question about Dell PowerVault 110T LTO-2 Ultrium Tape Drive
Cleaning tape - how often should this be done?
I have been advised to insert the cleaning tape when
1. The amber indicator light is on
2. Every 2 weeks
3. Also before and after I install a new tape.
Can you please advise which is correct.
Kind regards
Bev
  • Anonymous Sep 03, 2008
    I need drivers for the dell powervault 110T LTO-2
  • 54 Answers
You only need to use the cleaning tape when the amber light indicators!
There is no need to use it everytime you use different tapes, just when the light indicators will do as you can only use cleaning tape a certain number of times before replacing it.
Posted on Aug 04, 2009
Only when the light is on,
Posted on Jun 12, 2008
Dell Power Edge 2900 - amber and Red A light on tape Drive
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. May also be a defective card inserted into your motherboard. Try isolating the problem by removing all components until you just have motherboard and power supply and see if it turns on.
Feb 13, 2014 | Dell Computers & Internet
I have a DW027A drive. It is about two years old. I use NovaBackupServer software to run the backups. My backups started aborting suddenly. I get an error message that suggests there is no free space on...
Try manually expiring the media and rery the job. We can dig in more if you can clarify more on what the amber light is for..
Please come back and rate for me if this solution turns to be helpful for you.
Thnx :)
Mar 15, 2010 | HP Computers & Internet
2001 Tahoe cassette tape cleaning
I think you need to remove the unit and have it repaired, it is faulty.
Jun 07, 2017 | 2001 Chevrolet Tahoe
I have a Quantum SDLT 320 drive in a Dell 2800 server that has the yellow attention light stuck on. It is performing backups successfully in Veritas and giving no errors from Veritas or anywhere else. Can...
Sounds like it may be the cleaning light (far right)
You need to use a cleaning tape in the drive (they do expire after either 20 or 40 uses so use a brand new one to be sure)
That should clear the light. If it comes back on after another backup then try using the cleaning tape again and then a brand new tape for the backup.
If the light comes on again then the drive will need to go for repair as the head is knackered.
Try www.tape-drive-repair.com for this as they are pretty good price wise and also offer a 1 years warranty on their drives and repairs
Aug 13, 2009 | Quantum ValueLoader SDLT 320 Super DLT...
Canon xl2 will not take the tape it says remove tape in viewfinder.camera is dry whats going on here
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Mar 15, 2009 | Canon XL2 Mini DV Digital Camcorder
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
TAPE WON'T EJECT
YOU CAN TRY OPENING IT AND GETTING THE RIBBON UNSTUCK
Feb 21, 2008 | IBM (7208-011) 8mm Tape
Tapes won't play
This is an indication that both data heads are dirty. In a digital camcorder both heads need to be operating correctly to obtain a full picture. Insert a new cleaning tape and run it for only 10 seconds or less, this should clear up the problem. Avoid using the tape that caused the problem. Do not use the cleaning tape for regular maintenance, this will damage the drum surface. Good luck to you! Joe Weibel Custom Electronics (customelectronics.org)
Feb 14, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Dell PowerVault 110T LTO-2 Ultrium Tape Drive Logo
1,305 people viewed this question
Alun Cox
