Question about Symbol LS2208 Handheld
UCC/EAN barcodes How do I transmit the Function Code 1 (FNC1) for UCC/EAN barcodes. It works if i select tranmit 'AIM Code ID Character' but i only want the code ID for UCC/EAN barcodes and selecting this option tranmits for every code.
4 Suggested Answers
bluegreenash
  • 657 Answers
SOURCE: setup issue
you need to use a code book to program the gun how to behave (and by what kind of interface it is using) I found this note please look http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=ADC-00084&sliceId=SAL_Public&dialogID=26700221&stateId=1%200%2026686911 you should have a book of barcodes to customise the configuration of gun to behave how you want it to. here is the electronic version http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf&sliceId=&dialogID=26700221&stateId=1%200%2026686932
Posted on Oct 04, 2007
  • 4 Answers
SOURCE: we need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Posted on Apr 20, 2009
  • 74 Answers
SOURCE: I would like to transmit EAN-13 bar code without
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Posted on Jul 13, 2009
kganoe
  • 42 Answers
SOURCE: I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at support.symbol.com. Here is a short cut:
http://tiny.cc/d400s
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Posted on Mar 24, 2010
It scans 'k' at start with upc code
It sounds like the scanner has the Symbol Code ID character enabled and you are scanning a GS1-128 (formerly known as UCC/EAN 128) code. You can disable this by scanning the Symbol Code ID None barcode from Adobe page 211 of 460 (Chapter 12 page 3) of the LS9208 Product Reference Guide. https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/6083309a.pdf
Apr 18, 2014 | Zebra LS 9208 Omnidirectional Projection...
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
Cannot find a way to configure ls2208 to perform expansion of upc-a to ean-13 barcode. I need this characteristic enabled in order to transmit a complete ean-13 barcode when it starts with a "0",...
http://www.fixya.com/support/t1857832-need_convert_upc_barcode_number_ean_13
have a look there. it will explain.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Oct 01, 2010 | Symbol LS2208 Handheld
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Decoding properties EAN128. I need the data separator not to be removed (FNC1) for variable lenght application identifiers. How do i have to configure the 4410
If you generate your own barcode font, you may find the FNC1 character in the manual. In the ascii table for the font generator we use, the FNC1 character's ascii value is 102 +32 and is coded as (chr)134 in the code128c string. Most Iinfo online suggests the ascii character is 202 or 234 (?) or the character defined as "capital E with the circumflex", but that did not work for our barcode font.
Aug 24, 2009 | Falcon PSC 4410 (441000220)
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
Begin New Rule
Send Enter key
Save Rule
Jul 13, 2009 | Symbol LS2208 Handheld
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Setup issue
Oct 04, 2007 | Symbol LS1902T Handheld
Symbol LS2208 Handheld Logo
182 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
pkwc
volk1
Level 1 Expert
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
