Question about LG 42PX5D 42 in. Plasma HDTV
Thanks, but it isnt that simple. Most of the supply rails are OK, but the feed to the ZSUS PCB shuts down under load.........so a problem in just one part of the overall P.S. Hard to work through on the PCB as you need to undo a lot of TO220 components to be able to work both sides of the pcb! Good suggestions! Thanks
    Genius:
  • 1,554 Answers
Well I just had coffee so thought I would share tips.
if you do something like I do when working out a system .
shoot a digital picture and print or edit it on-screen.
start by documenting removed and interconnected components.
mark inputs and outputs, then power flow, regulation, feedback
then mark the main divisions to each circuit
look for a data bus. HV area,
document the hot spots and damage
if it can be maintained in shutdown mode what area got cool.
a thermal picture of board would be very helpful but you can map it manually using hands , ir sensors or thermal probe (insulated)
I use an audio probe in a lot of circuits to listen to the signals.
though some scopes have audio and digital capture I found audio to be a lot faster once you get used to it. you can hear heat noise in the dc signals, you can hear caps ticking, data sounds digital. even different voltages have special sounds.
once you make this map of a board you will find troubleshooting much faster and easier as you record the data.
print out a couple of copies and work out a system to get to them quickly.
the hardest of all but necessary is to make a rig to run the unit outside the unit.
Get yourself a good analog meter, on the Rx1 scale it puts out a small bit of voltage so you can test transistors ,diodes and cap all in-circuit , reason. if you watch the rise of the needle and speed it falls, you can tell the overall time of the charge /discharge of circuit or cap.
It is by caffeine alone I set my mind in motion, It is by the beans of
Java that thoughts acquire speed, the hands acquire shaking, the shaking
becomes a warning, it is by caffeine alone I set my mind in motion.
Posted on Jun 12, 2008
What does a pcb look like i want to make sure i am right
PCB means printed circuit board.All the boards in your TV are PCBs, Please specify which board. example YSus, ZSus, Power Supply. Control board, YDrivers etc
May 17, 2014 | LG 42PC3D 42 in. Plasma Television
Will not power up. Tested from plug to power board. Power does not leave power board from any terminals.
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
Nov 25, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My Hobart 175 Handler wire feed stops shortly after the arc is struck. Recovers in about 20 seconds. Motor protection ckt is probably doing it. No restriction in feed cable or gun, wire moves smoothly....
Yes sounds like it is "Detecting" a "Fault" condition and shutting down the Arc for safety, then it recovers, and it repeats, I think, you should Check, your Earth leads, Connections, and Overcurrent Protection Threshold if there is a control. Check power is going to the feed motor at time of arc, and if it is still getting enough or if it, the voltage to it,"Sags" under load...In this case it is a power supply problem.
Mar 10, 2010 | Welding Tools
Power cord buzzes and MACPro does not recognize it
This is a fault in the power supply itself, I have just repaired one of these power supplies successfully.
The fault is caused by the failure of the filter capacitors on the 12V supply rail, and if the power supply is left connected to the mains supply (In our case 240V 50Hz) without the drive connected as a load, the unloaded output voltage will exceed the voltage rating of the capacitors, causing their failure. The failed capacitors had very obvious bulges at the top, and one was beginning to leak onto the PCB.
The filter capacitors on the 12V supply rail are rated at 16V, and the cpacitors on the 5V rail are rated at 10V, and when operated without a load, the 12V rail rises to approximately 19V, and the 5V rail rises to approximately 8V. All output filter capacitors are 1000uF, and 105deg C temperature rated.
I repaired my power supply by replacing all of the filter capacitors on the DC low voltage output rails with 1000uF 25V capacitors. Be careful to only fit the 105 deg C rated caps, as they operate at elevated temperatures in an enclosed environment with no ventillation to cool the power supply.
To ensure that the repair was reliable, I also replaced the filter capacitor on the 5V rail with the same 1000uF 25V, even though that capacitor showed no immediate signs of failure.
When reassembling the power supply, care must be taken to ensure that parts like the ferrite cored transformer are thermally bonded to the aluminium heatsink with a smear of heatsink compound.
When the power supply was first powered up following repair, everything was normal, the green power LED came on as usual, the supply outputs both came up OK, and the unit was not making any buzzing sounds, completely silent. The HDD now operated as normal when once again powered from this power supply.
This was the fix for my particular LaCie power supply model ACU057A-0512, and the supply once again works normally.
Tim,
Brisbane Australia.
Mar 12, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have an LG WM1814CW not getting .
Did you check the simple things first?
Often, one of (up to) three screens are in line with both water feeds; one at each end of the connecting hose, still another at the input to the control valve.
Feb 07, 2009 | LG WM1814CW Front Load Washer
Loading the paper
Cut the paper off clean.
Slid it through the slot on the back.
The place the paper between the black plastic rail,
and the bottom of the calculator.
Keep feeding it in the slot untill you can see it under the
foam wheel.
The repedably hit the feed button until the paper comes
out the other side.
If it does not feed, the paper is not under the wheel far enough.
This should work on other similar models as well.
Dec 24, 2008 | Casio HR8TM Calculator
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Oct 22, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
DU-42PY10X Has sound but no picture.
When a plasma has no picture I have found that 9 times out of 10 the ysus bd or the zsus bd has failed and sometimes both have failed at the same time. When you pull the back of the unit, you will find the the large pcb on the left as you look at the back is the ysus bd. and the bd. on the right side of unit is the zsus (it is about 1/2 size of the ysus bd. Check the fuses on both bds. and if one is open see if replacing will help. If it blows again the bd. that the fuse is on is most likely defective. The VS and VA voltages are listed on a tag on the inside of the plasma panel and those voltages should be checked. If either of those voltages is very low or missing, first disconnect the plug from the power supply to the ysus bd and check the voltages again. If the voltage comes up then the ysus is defective. If the v does not come up replace that plug and pull the plug from the power supply to the zsus bd and check again. If the v then comes up the zsus is most likely the cause. Remember to disconnect the AC to the unit b4 each step. Of course there are other possibilities and I alway reccomend that if your are not proficient with handling meters and AC and DC voltages then please contact a qualified service tech.
Feb 02, 2008 | LG DU-42PY10 42 in. Plasma HDTV
Lg 50px4d
LG 42" Plasma TV 42PX3DCV Parts - YSUS ZSUS CTRL Part Number (set): 6871VSNB03E Part Numbers (individual): 6871QYH036D, 6871QZH041B, 6871QCH053G Part Number: 6871QYH036D Description: PCB ASSEMBLY, DISPLAY YSUS ASSY 42V7 FOUND THESE ON THIS: http://cgi.ebay.com/LG-42-Plasma-TV-42PX3DCV-Parts-YSUS-ZSUS-CTRL_W0QQitemZ110086231102QQihZ001QQcategoryZ116199QQcmdZViewItem HOPE IT HELPS
Feb 26, 2007 | LG 50PX4DR 50 in. Plasma TV
NEC FS-8001
NEC is famous for under rating it seems there sets. Not sayying that the sets are not good but I've seen hundreds of NEC with what looks like over heating. I too hace seen several power supply problems and it comes to mind that a small choke that looks like a small resistor with wire wrapped around it has been the problem several times as you must also take out the parts that looks burnt and clean the area and take off all the overheated solder and clean up the pcb and reinstall and resolder with new solder if you want to not have intermittant connctions again. Oh almost forgot that these coils are on the output of the power supplys and make sure you check all the caps as well in the output of the power supplys as well as in the sweep supply as this can cause your sort of problem as well.. Good Luck PS if a resistor looks burnt they are so cheap you should replace it as resistors that look or have been overheated can and will breakdown under power or a load.
Apr 11, 2006 | NEC FORTRON/SOURCE 145W POWERSUPPLY...
LG 42PX5D 42 in. Plasma HDTV Logo
175 people viewed this question
Henry  Thomas
Henry Thomas
