Coming out of the back should be a 1/2" NPT short nipple, or a check valve with 1/2" NPT threads. ( NPT = National pipe thread. Just ask for a 1/2" galvanized pipe nipple the right length.(short, or 2" usually) If it's a check valve, it will usually be brass or plastic/nylon. I prefer galvanized just because the tend to hold up better. Most water lines connect to that, unless yours has a different fitting such as a female flare going to a male flare fitting in tank. Either way, you'll have to get old one out and match it, to allow for water line fitting to re-attach, or change end of water line to proper fitting to attach to nipple. Without seeing exactly what you have, I can't explain exactly what you need to do.
