Question about Candy CNW156 Front Load Washer / Dryer
Bearing fix Candy CNW156 Front Load, I want help to replace drum bearing please.
    Champion:
  • 249 Answers
That job is for a very skilled person I would not take it on unless you are that person,by the way it comes in a kit TWO bearings and water shaft seal I would replace drum shaft as well Eamonn Ireland
Posted on Jun 12, 2008
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
How do I remove drum bearing from Candy CNW136 WASHER / DRYER
How do I remove bearing from Candy CNW136 washer/dryer.
Thanks
Reply to rsparling@manutec.ie
Jan 20, 2011 | Candy AQW130 Front Load Washer / Dryer
Hi, I have a candy Grand O GO1682 washing machine and on spin it is making a very loud rumbling noise, So i am assuming this is the drum bearing, But What is the part number, is there more than one, and is...
I HAVE THE SAME PROBLEM, AND A ENGINEER SAID THAT THE BEARINGS HAVE GONE AND THAT IT TAKES 2 PEOPLE TO FIX IT AND THAT THE BEARINGS 7 DRUM COME AS ONE COMPLETE SYSTEM AND WILL ROUGHLY COST ABOUT £200 AND TAKE ABOUT 2 HRS TO FIX. SO IS IT WORTH IT OR BUY ANOTHER ONE INSTEAD.
Oct 13, 2010 | Candy CN136 Front Load Washer
Is it possible to change bearing myself on machine? I have the back off but can't see how you get it off?
Not the simplest of jobs unless you expert diy.....Advise engineer, quite expensive job 1- 2 hrs labour + materials which could cost over £70........
May 03, 2010 | Candy CNW156 Front Load Washer / Dryer
Candy CNW156 Washer / Dryer and the dryer stopped working can you help
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 14, 2010 | Candy CNW156 Front Load Washer / Dryer
Bearings are going, lots of noise from drum when moved by hand
You have diagnosed the problem yourself. Now you need to get a quote for the repair, which is a major job. Call around your local repairers and see if they will give you a rough estimate, without having to pay for a call out.
You might find it is better to replace the machine.
Also always best not to overload the machine. For example a 5Kg machine does not mean that it will take 5KG worth of dry towls. Imagine the weight of the towls once soaked. That will probably be 3 bath towls max.
Good luck.
Ash
Oct 22, 2009 | Candy CNW156 Front Load Washer / Dryer
Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Dec 01, 2008 | Candy CNW156 Front Load Washer / Dryer
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy CNW156 Front Load Washer / Dryer Logo
193 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
