Question about RCA Televison & Video
DVD player power lights are on but nothing works, tray won't open and manual bottons don't work either.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
First, you should open your unit to see inside and look for the belt it maybe cut, thats the one reason why your unit will not open.If you cannot see the belt,i would suggest to bring your unit to a qualified technician....
Posted on Jun 14, 2008
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
Menu bottons will not work flashing open disk tray
I have one that does that but I can still use the VCR for manual (not timed) recoding.
Get used to using VCR again.
It also serves as an AV1 to RF converter on dish units to RF TV's.
Apr 05, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
When I turn the power on, the power light comes on but there is nothing on the display of the DVD player. If I play with the power switch a few times, then the display will comes on and the I can...
The DVD player unit have a power switch that have cold soldering circuitries joints,u have tools like soldering iron and roll of solder also can do basic soldering work?Yes.Take the unit aparts and do resoldering work to the power switch.If u can't do soldering work and don't have tools,just replaced the DVD player unit,buy a new one.It cheap these day.The new one only will cost u like $40 brand new,not worth it,if u require hiring a repair shop to do the work for the unit.
Apr 27, 2011 | Apex Digital AD-1600 DVD Player
I own a Memorex DVD player, model MVD2030 which hasn't been used for 6 years (when I moved). Tried to set it up today and find the "open/close" button does not function. Any ideas on how to resolve this...
its not problem at all.
if you have an old stereo or tv set you can use one of the small push botton to replace it.
you will need screw drivers, solder, suction and some patience to do the job. that is if the botton is making bad contact.
the problem can be a bad driving IC.
try to open the casing, locate the open/close motor, turn it manually to fully open tray. plug the set into power and try to close the tray. does this happen and still the tray wont open with the botton, then your driving IC is bad. i dont know if you can change the IC, its small and maybe and SMD.
Aug 26, 2010 | Televison & Video
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
Disk wont open or close
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Nov 19, 2007 | Microsoft Xbox 360 Console
DVD tray won't open
Hi kjflynn06 let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
Apr 25, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
