Question about Samsung HT-DS1000 System
Samsung ht ds1000 audio problem
Hi there, i'm having problem with my ht ds1000. there's no audio coming out from its speakers - sub is connected to the unit so as the video cable. i have video by the way. thanks in advance for your input.
  • searchmaster Jul 31, 2008
    I have the same problem. No audio just video. This problem happened when my daughter inadvertingly brushed against it. It made a loud static sound and the audio is gone. Samsung support is no help either. They can't fix it.
  • Anonymous Aug 18, 2008
    i have the exact same problem with Samsung HT-TXQ120...
    so ALL the cables are connected properly, everything worked great until now... i play a DVD, there is image, but no sound... furthermore, if i try to switch the audio style [change from concert to movie, virtual 9.1, stereo 5.1, and so on] ... it doesnt work anymore, it shows nothing on the screen anymore...
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
Posted on Dec 19, 2008
I have an HT-DS1000 I bought used. The FM tuner works, the CD player works ok, but it will not read DVD's at all. It just continually says "loading." I hooked up an alternate DVD player...
Optical pick up out of tolerance. If you take disc out it should stop clicking. The clicking is the optical pick up lens hitting max extension due to focus not being achieved
Apr 25, 2017 | Samsung HT-DS1000 System
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
SURROUND SOUND
Do you have HDTV with Digital Coax out or Optical Out? If you do you can connect your surround system rear port mark Optical In from your HDTV Optical out. Tosh link fiber cable..
Now if you don't have HDTV with Digital out nor a HDTV but CRT set with Analog Stereo output you can connect using RCA left/right cables to bottom of the unit where you have HDMI, Component and Audio out. This is where you would connect your TV too. For audio playback using the AUX mode.
Jul 23, 2008 | Samsung HT-DS1000 System
Samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
Jan 19, 2008 | Samsung HT-DS1000 System
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
DVD turns off with "Protection" message.
it may be becoz you are using too many things from 1 plug socket / power adapter.
Aug 14, 2007 | Samsung HT-DS1000 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Samsung HT-DS1000 System Logo
208 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
