My printer will only print in blues pinks and purple and black and white
  • golex Jun 12, 2008
    My printer will only print in strips. It is a Canon i560.
    Master:
  • 638 Answers
Ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Posted on Jun 12, 2008
4 Suggested Answers
  • 37 Answers
SOURCE: Purple printing as pink
No problem
Posted on Dec 05, 2008
  • 52 Answers
SOURCE: won't print correct colour
Try printing a test page. If it comes out missing colors, the you color cartridge is bad. HP test pages will print each of the 3 colors by them selves, so you can see if you are getting all colors. If this prints ok, the I would think it is not a printer problem.
Posted on Mar 06, 2009
  • 60 Answers
SOURCE: Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Posted on Apr 06, 2009
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Iwould like to switch the radio in my truck but dont know which wire is which
2000 Ford Expedition Stereo Wiring Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) White/Red Left Front (-) Brown Right Front (+) Green Right Front (-) White/Orange Rear Speakers 6" x 8" Rear Doors Left Rear (+) Light Blue/Black Left Rear (-) Yellow Right Rear (+) Purple/White Right Rear (-) Light Blue
Hope this helps
and please don't forget to
rate the answer it helps me
with my general ratings.
Thanks!
Apr 11, 2010 | 2000 Ford Expedition
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Dec 18, 2009 | Office Equipment & Supplies
Apr 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
What are theorange , yellow, blue ,red, and black wires for on th
Speakers
left front
white/black -
white +
right front
gray/black -
gray +
left rear
Green/Black -
Green +
Right Rear
Purple/Black -
Purple +
blue = motor antenna
blue-white = Power control wire
pink-black = External amplifier
orange-white = dimmer control
brown = mute wire
yellow = battery
red = acccessory
black = ground
Nov 28, 2008 | Kenwood KDC-322 CD Player
Colors not printing right
Without a model for the printer it is hard to say. But is if is a standard bubblejet printer with a colour and a black cartridge, then chaces are your colour cartridge is low on red (magenta)
Apr 13, 2008 | Office Equipment & Supplies
642 people viewed this question
jasbo
jasbo
