Question about Dishwashers
Dishwasher continues to drain (flashing "Eco" light displayed)
  • tracykeane Jan 15, 2009
    My dishwasher continues to drain even when it is empty. The cycle then does not come to an end.
  • 833 Answers
Sounds like a bad solenoid from what I can gather. There is a drain solenoid and/or a spray solenoid in most dishwashers. The pump output is directed that way. If your solenoid is hanging open, the water will drain when it shouldn't. It is either bad or has some kind of material in it.
Posted on Jun 13, 2008
SOURCE: Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
Posted on May 22, 2008
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
  • 157 Answers
SOURCE: HOTPOINT AQUARIUS FDW60 ECO LIGHT FLASHING
Check pump is running
Posted on Dec 19, 2008
  • 134 Answers
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Posted on Feb 14, 2009
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Our Dishlex Global 300 appears to be stuck in Pre-wash. The Eco light is flashing and the water has drained. All other buttons are unresponsive. I have just replaced the seals and handle assembly.
If your getting 120 volts to your dishwasher, I would first ohm out your thermal fuse for continuity, turn your breaker OFF to your dishwasher first.
Jul 24, 2008 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Jul 01, 2008 | Dishwashers
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
