Question about Haicom GPS
SD reader of HI-305 III seems to do not work on Ipaq 214
I would like to know why the SD reader included with your CF card Haicom HI-305 III seems to not work with pda HP Ipaq 214 with Wm6 and default configuration. I have installed the included driver elsdmmc but it doesn't yet recognize the reader and it doesn’t create the directory to see the SD contents. I know for sure that the same card works correctly with other pdas. It is a problem of some incompatibility or what? There are some workings around? Could you help me please? I thank you in advance for you answer.
  • 263 Answers
SOURCE: Cisnet card reader
yeah you need drivers for the sd card http://www.driverguide.com
Posted on Jan 05, 2008
thejus
  • 19 Answers
SOURCE: SD Card Reader
PLEASE SPECIFY U R SYSTEM BRAND AND MODEL
Posted on Jan 11, 2008
  • 107 Answers
SOURCE: FineDrive 400: Original SD card got corrupted!
you need to reload the firmware in the unit and reload the map data on the SD card, this will fix your issues. as finedrive is not around anymore, here are the files:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Posted on Feb 22, 2008
SOURCE: driver for Haicom HI-204E-USB
I have what you need. Take contact with fromafoggy@hotmail.com to contact me. I am norwegian
Posted on Aug 01, 2008
  • 29 Answers
SOURCE: SD card reader seems to be dead
Need Tech Support?
Dan Kim DVS Sales {OEM-Plenio-Rep}
408 970-3388
www.dvssales.com
JEFFREYDRESCHER@bELLSOUTH.NET
Plenio VXA-3000 Owner
Forget The Nail, Plenio Is Not Detecting SD Memory Chip, Sound's Like It Is Not Fully Seated
in Reader On Plenio, Call Kim
Posted on Jan 15, 2009
IPAQ 214 get stuck while working with FTDI driver
nobody uses these now
but why not ask hp.
they get a great laugh,
here it is wait for it, the REAL HP, (drum rollllllll)
https://h30434.www3.hp.com/
Oct 22, 2017 | HP iPAQ 210 Pocket PC
My hp ipaq hx 2790 don't read the memory cards
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Jan 08, 2009 | HP iPAQ HX2790 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
SD Card not reading
I had this problem once and found after tedious looking that one of the pins was bent inside my HP 3715 PDA. I used a very small needle nose and a safety pin and pushed it back in location. Has been working ever since.
Mar 22, 2008 | HP iPAQ HX2490 Pocket PC
Cisnet card reader
hi, the USB port might be recieveing the power, but the card chip must not be , try cleaning the contacts, or try some other reader to see if that works.. let me know
Jan 04, 2008 | ZT Group Cisnet T2060 Notebook Computer
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
SD card slot stopped working
Really maybe you don't know a lot of fixya in the philippines. Try to send your device here in Dipolog City.
Nov 20, 2007 | HP iPAQ H2215 Pocket PC
IPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
File Transfer
Use file explore option in Activesyn or just use a SD card reader to transfer music, pictures, etc. to the card. It's much faster & easier.
Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
GPS Logo
141 people viewed this question
Top Haicom GPS Experts
Will Halftowaite
Are you a Haicom GPS Expert? Answer questions, earn points and help others
