Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity frontload washer ATF6000ES
During a thunderstorm when the lights in the house would fade and come back to normal the door on the washing machine would lock and the chime would sound and the washing machine would start to fill with water. It done this five times and finally we unplug the machine. Any suggestions to what might be causing this.
  • 525 Answers
Plug the washer back in and try it again. Sometimes a power fluctuation will cause a "polarity reversal" so to speak, or a static build up that can be relieved by merely unplugging the unit. This allows certain internal control board components to discharge and reset themselves. If that doesn't work, then you will probably have an issue that is only solvable by a professional servicer.
If this helped solve your problem, please be kind and rate how valuable my solution was to you.
Loved helping, thank you for contacting me at
Dave E. (Illeagle)
Posted on Jun 12, 2008
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
I have teh atf6000ES1
Pau? as in end of life? seems that perhaps the control board is speaking in a foreign language? anything happen recently to make it this unhappy?
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frontload washer, affinity
you have to take the front lower panel off if it is the piece im thing about if not you have to dig the front off be careful on how you take it apart because it has to go back together the same way good luck
Dec 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
