if you are absolutely sure it is the bearing, you will need a special tool to pull the old one off and press the new one on. My advise is to have a professional repair person do the job.
The Candy front load machines have a three-pronged support at the back for the drum. This sometimes get cracked or broken, when this happens, you will have to replace the entire drum assembly as the support is riveted on to it.
The broken support causes the inner drum to rub against the outer tub, giving the impression that the bearing is bad.
Hello
This is fairly straightforward but little hard work to remove and fix.If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor ,the replacement will be as follows that I have done successfully
1.Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame. 2.Take the complete drum assembly out of the washing machine frame. 3.Leave the drum assy on a bench with pulley side upward, usepuncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up. 4.Then keep punching until drum spindle and the “Y” arm assemble comes out. 5.Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing. 6.Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal. 7.How to get the spare parts; these parts are very common in this geographicalregion ( Asia). You can buy generic parts.Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referredas oil seal, look for specifications such asspecs will have inner& outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one. 8.Install back the new parts: you need to smoothen thespindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles. 9.1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well. 10.The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely,then pulley can be installed. 11.The drum bearing replacement is completed 12.Re-install the other parts back.
Pub
Candy Aquaviva 1300: which ever program is selected the machine seems to do part of the wash then...
(More)
Candy Aquaviva 1300: which ever program is selected the machine seems to do part of the wash then the selector just click?s as it rotates and the machine stops part way through the program. Help please.
hi,
our candy aqua 1000T trips its fuse somewhat arbitrarilly. sometimes it works fine for wash...
(More)
hi,
our candy aqua 1000T trips its fuse somewhat arbitrarilly. sometimes it works fine for wash after wash, and then it will trip, and we won't be able to get it started again for up to a month.
we've lived in 2 different places with it, so we don't think its the electrics in the house, but we can't seem to find a correlation between the power being cut out, and anything else! doesn't seem to be related to the cycle its on, or what is in the washer, but ideas are welcome!!
thanks,
erin
The machine washes OK, drains OK, and the drum seems to turn (slowly) during the cycle. However, it...
(More)
The machine washes OK, drains OK, and the drum seems to turn (slowly) during the cycle. However, it does not want to spin (fast). Hence the clothes come out v. wet.
There is excessive play on the drum mechanism and the rubber (possibly called the door seal) has...
(More)
There is excessive play on the drum mechanism and the rubber (possibly called the door seal) has partially disintigrated, which is preventing the drum from going round (even manually ) Whilst I know a definate replacement (door seal ) is needed, could anyone tell me me if it is possible that anything has caused this to go, such as the bearings, or do door seals just go? Any help or feedback would be appreciated..many thanks in advance. Jay
