Question about Samsung OKIDATA - OKI C5200n - Printer
OKI C5200 - Faded black print area
I am getting a faded streak in the same place all the time where there is black print. All the color areas of the document are fine. I changed the black ink cartridge and have same problem. I wonder if the drum needs to be changed even though I changed it when indicated 6 months ago.
  • msteider Sep 25, 2008
    I tried the fix listed but that didn't work. The image drum is fairly new so I don't think that is the problem.
  • 134 Answers
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Posted on Jun 12, 2008
  • Mike O'Conor Jun 12, 2012
    This is an amazing answer! Fixed what I thought was a drum problem right away! I love a quick fix!
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Faded lines of black across part off printed page
please you used the colour printer ? if yes then your check the csrtridge a refeling the towner and service the cartridge and service in printer and aply the print is ok.
Sep 22, 2009 | OKI C9300 Led Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Nov 27, 2008 | Dell 3010cn Laser Printer
Black text or black print is faded in a 2" vide area
Although the drum life is at 65% it could still have a problem. It could be that the end of the drum is starved of toner or there is lumpy toner in the drum. Take out the black drum and give it a good shake then a gentle one to level the toner out and refit. Had the same with a canon unit 2 weeks ago. If still no good then a new drum is required. I bet you are using recycled drums!!
Sep 23, 2017 | OKI C5200n Laser Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
Samsung OKIDATA - OKI C5200n - Printer Logo
553 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
