Question about Samsung SGH-D900 Cellular Phone
Network printing error
When i am giving a print command to a printer that is in network , i am receiving the following error
the file could not be printed due to an error on \\xxxxname\\xxxprinter on neo4
i am using windows vista
tried everything that i can do
like removed the driver and installed it
connected via a local port
and then giving the part
mess up
hitesh
    Brigadier General:
  • 7,752 Answers
Vista is not a good o/s to use with networking pcs
Posted on Jun 28, 2008
Why is it I receive an error message "undefined" Offending Command: Operand Stack? What do I need to fix this?
This is an issue between the file you're trying to print and the printer not being able to read it correctly.
Try copying it and pasting it in a new document (preferrably different program) If that doesn't work, try to install and use another driver
Jan 20, 2015 | Xerox Phaser 6200N Laser Printer
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
Epson stylus C44UX and zps1001 zonet print server
Since it's over a year since we had any response on this, I think we might call it "Solved by Poster".
Jan 13, 2008 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Samsung SGH-D900 Cellular Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
