Question about Nokia 5200 Cellular Phone
Reply to solution again
Ok here's the response to all the things u said
first i used a CARD READER: it keeps trying to search for autoplay and fails. sort of like its trying to read and not getting access.
--double clicking on the drive: "operation could not be performed becaude of I/O error"
--fomat the drive: "there is no disk in drive"
tried in SAFE MODE: exactly same as above but without the autoplay ****.
i kinda dint get how to use FAT format to reformat.
let me know what to do. thanks :)
phone: nokia 5310 xpressmusic
mem card: micro sd
    Brigadier General:
  • 7,752 Answers
Tale the phone mem card to a mobile service center and have them removed the code.
Posted on Aug 26, 2008
I bought a second hand HIS ATI RADEON 4670 1gig agp, we test it first and works fine also in my pc, then after 1 week used the video card shows no response to my monitor totally blank screen so i had to...
The card could be failing. Try checking that the fans are turning on the HIS when computer is on. Also make sure the heatsink under the fan is fully touching. The card may think it is overheating so check all the connections under the cover on the HIS card
Thanks for using FixYa
May 21, 2011 | HIS RADEON HD 4670, (1 GB) AGP Video Card
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I shot alot of pictures on my sony cyber-shot W55 and when i wanted to view them it says file error
It may be a problem with the memory card. Try the card in a card reader or another sony camera. If it works ok then, you've a camera problem.
If it fails also, it's a card problem, the files are corrupted somehow, the only thing in this case is to re-format the card in you camera, it will be one on the menu options.
The trouble is, when you format, it clears every thing off the card.
Another way is to buy a spare memory card, always handy, if that work ok straight away, again your first card has a problem and probably needs formatting.
Apr 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Windows explorer non responsive when sd card inserted. Computer runs slow when using Serif PhotoPlus 9 or 10 and eventually becomes non responsive.
Hi p_allchin1,
This probelm usually occurs when there is problem with the card reader device or even due to faulty cable between the card reader and the System, try replacing the wire and if *** fails replace the reader....
There is a chance of this problem occuring due to Faulty card also..
Ebjoy!
RNJ VINOD KUMAR
Jul 01, 2009 | Acer Aspire M1641-U1521A PC Desktop
Problem with N72
ok..then try formatting ur fone first without the card..n then try again try formatting ur card.If the same thing happens u'll have to scan ur card for errors n badsectors using a pc.
Feb 12, 2009 | Nokia N72 Cellular Phone
Screen goes blank on Log on
Use PC wizard (search and download) this will detect all drivers needed on your computer note name and number for your video card type into search engine IE ati x300 drivers for your operating system xp vista you should be able to download correct drivers
if does not work for you please leave reply what happens
Jul 23, 2008 | HP RADEON X300 SE, (128 MB) PCI Express...
Reply to solution
ok connect the card reader & put memory & try going in safe mode ...
i hope you know how to go to safe mode ... (it is pressing f8 key before the OS boots)..
if still problem persists then Use FAT format to reformat.... when you put it into a MMC Card reader.
if it reads in your phone then try deleting everything in that ...
& also try to check the errors in that drive when connected to pc after this try formatting ........
Jun 10, 2008 | Nokia 5200 Cellular Phone
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
Nokia 5200 Cellular Phone Logo
343 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
