Question about NEC PlasmaSync 42VP4D 42 in. HD-Ready Television
Plasma 42 inch nec
I moved house and when i plug my antenna in an try to chune channels in it wont let me it keeps coming up saying that i need to plug the antenna in even though i have it plugged in what is the matter with it please help
  • 58 Answers
The problem is most likely that there is no signal on the cable you are using.
check with a regular tv to make sure you have a signal.
Thanks
guy9
Posted on Jun 12, 2008
I have a 42"zenith plasma tv. Been trying for hours to auto tune,none of the channels come in.
What is your input source? Is it Antenna, HDMI, Component or Composite.
The Autotune is only for Antenna input when connected to an indoor or outdoor antenna, if you are connected to a cable or satellite STB then that is what will do the tuning.
Oct 02, 2014 | Zenith P42W24B 42 in. Plasma Television
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have 42 nec plasma when i turn on work normaly but after seconds picture became dark
Have you tried changing the input? Meaning, as soon as you power the screen on, press the "input select" button then wait a few seconds if nothing comes up press it again, do this until you find your connection and you should be set. This problem seems to keep coming up with this particular Plasma, so I guess I'll keep on answering. Good Luck
Jan 06, 2010 | NEC PlasmaSync 42MP2 42 in. Television
I have 42 inch toshiba, my husband cancelled our cable, is there a way to get the tv to work for just local channels??
The instructions are in your TV manual, but because of the complexity of the TV and it's features, it may be difficult to find. I believe it is on P. 31 (at least of the manual I got online). You'll need to connect a TV antenna appropriate for your area. If broadcast sites are close (line of site) a simple bookshelf antenna will work. With the antenna connected, and the antenna input selected in setup, you allow the TV to scan for local channels in your area. I hope this helps you.
Nov 21, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
Jul 22, 2009 | Televison & Video
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
Cracked Plasma
For the cost of the replacement screen, it's a better option to replace the unit I'm affraid.
The only time you would consider repairing this would be if it were a part of say a video wall and needed to match the rest of the units.
Apr 16, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Plasma flicker
G'day mate,
A good HD antenna and proper orientation should do a lot of help. In the USA, a website guide HDTV owners to properly identity a suitable antenna and orientation. Check out:
http://antennaweb.org/
A similar website may be available in Australia.
If not, what you would want to do is to point the HD antenna to your source of Free To Air (FTA) broadcast.
Cheers!
Mar 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
NEC PlasmaSync 42VP4D 42 in. HD-Ready Television Logo
117 people viewed this question
Top NEC Televison & Video Experts
Brian Sullivan
Brian Sullivan
Dave Naylor
Dave Naylor
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
