Alignment is messed up.
I have put new ink cartridges in my Lexmark X4580 and now the alignment is all messed up. I've tried different cartridges, uninstalling the software and reinstalling and the alignment is still messed up. Please can you help me out!
  • ktlt Jan 11, 2009
    hi how do i run a cleaning cycle or allignment? my ink is new but prints lines going through it. I have been told to clean it but i dont know how? please help, i have an HP C3180
  • 120 Answers
I would suggest running it through a cleaning cycle or two.
Posted on Jun 13, 2008
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
My lexmark 640 printer is not printing ie blank page after printing, yet the ink levels are high as i've hardly used it. what can i do, please? sandy
Print quality issues can be due to clogged print cartridge nozzles. Please follow the steps below to fix the problem:
  1. Try to remove the cartridges from your printer
  2. Close the printer cover.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reinsert the cartridges.
  5. Your printer will then try to print an alignment page. It will help clean the cartridge nozzles.
  6. After the alignment page comes out, try to print a document again to verify if problem is resolved.
If the problem continues, try to launch the Lexmark Solution Center on your computer. Go to Maintenance and select Clean Cartridge.
You can also try to insert a different known working cartridge to determine if it's a cartridge problem.
Aug 18, 2011 | Lexmark Z640 InkJet Printer
I just put in a brand new black ink cartridge. The alignment page doesn't show the black ink and the printer kept saying alignment error
It could be that one of the cartridges is not seated properly in the cartridge carrier. Try to re-seat the cartridges in the cartridge carrier.
Aug 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just replaced ink cartriges in printer and followed instructions but still saying i have an alignment problem
Make sure you are inserting genuine Lexmark cartridges. Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You could also try inserting a different known working cartridge to determine if the other is faulty.
Jul 26, 2011 | Lexmark X4580 InkJet Printer
Alignment problem on lexmark x4650 printer
Try this
Turn off you printer
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
Feb 25, 2010 | Lexmark X4650 InkJet Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Low ink indicator and I refilled my cartridges, how do I get my printer to recognize they are now full?
Open the Lexmark control Panel and select the Ink Cartridges Alignment tool. In the windows should be a place where you can select whether you have installed new ink cartridges. Also, make sure you do the alignment before trying to print. Finally, if you're using replacement type cartridges made by a third party company, they may not be detectable by the Lexmark system... many are not 100% compatible and don't have the electrical connection properly designed to be readable by the Lexmark software.
Oct 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
Put in a new black ink cartridge #32 in my lexmark X5470
Try arrowing down on your screen to maintenance press the tick to select maintenance and then scroll down to align catridges. see if this works
Jun 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Alignment of cartridges
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
266 people viewed this question
jasbo
jasbo
