Question about Motorola Mobility C168 Cellular Phone
Not charging my battety not chrging when i setel the chrger it display charging but when i remove charger the masaage low battary and even than it sow high temprature.
  • Anonymous Mar 26, 2014
    my phone is not charged by htc charger
  • 47 Answers
Clean you battery contacts and try to charge use a alcohol based cleaner or contact cleaner then try to charge if battery is getting hot its shorting out be prepared to replace battery if you haven't had the phone very long you might be able to replace with your service provider you'll need that battery number thats on the sticker and call your service provider and ask about warranty program you'll probably need a credit card for the proses
Posted on Jun 14, 2008
  • 58 Answers
Hi
Measure the voltage of ur handset's battery by multimeter and the voltage should come minimum 3.0. Only then that will be charged.
Request any skilled mechanic to check the components related to charging and if then is fault then repair it.
Supriyo DG
Posted on Jun 13, 2008
Mobile display problem
You need to charge it for at least 6 or 8 hours. Then unplug the charger and try turning it on.
Nov 08, 2013 | Computers & Internet
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
I have a Nokia 6630 Second hand phone.Sometimes I have displayed 'Not Charging' when I am using my NOKIA Original Charger. but my charger is working properly.Is it a battery problem or Power IC problem
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please
OR:
Please change Phone In The CHARGING JUMPUR
rate my answers too
Dec 28, 2010 | Nokia 6630 Cellular Phone
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
Thinks car charger is a usb adapter
I feel you might have one of two faults here ether or so do not shoot the messanger.
1. Bad card chrger
2. Failed chrging element inside (usb controller)
I work on these things for people to have enought expertise and working knowledge to let you know what it could be and for you to make the choice to check it. Do this
Plug it into a computer if it does charge replace the car adaptor you be glad you did. If it does not charge on the usb take the unit it for repair. Now if this is under warranty take it in to have it repaird.
Thanks for using fixya.com please do leave postive feeback for your free answer today.
Dec 07, 2009 | Magellan Maestro 3225 Car GPS Receiver
When i am charging my motorola mobile the display comes like ''UNDER TEMPRETURE'' means what.
When charging any phone and it indicates: Under temprature, it simply means the charging point or the charger might have gone bad.
Please get another charger to trouble-shoot, if this does not stop it then let an expert confirm if the chrging point of the handset is bad.
Good luck and rate this too.
Jul 29, 2009 | Cell Phones
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
Sharp vl-nz50
i need the software and the driver for my video camera
Nov 25, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Motorola Mobility C168 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
