Faulty samsung 913V - Computers & Internet
  • 3,940 Answers
OK, you have a Syncmaster 913v.
Here is a link to it on the Samsung site:
http://www.samsung.com/us/support/troubleshooting/troubleshootingGuidesList.do?dType=D&vType=L&prd_ia_cd=05020100&model_nm=913V
If you need service/replacement there is a warranty link there too.
If you need more assistance, post back with specific details describing your problem and we'll try to assist.
Posted on Jun 12, 2008
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung monitor syncmaster 913v
Either you messed badly with the system color profile management, or, more likely, the VGA cable is faulty or improperly seated. Try unhooking the PC end of the cable (and, if you got yourself a model with removable cable, also the monitor end), and hook them back again, seating the connectors gently but firmly and tightening the connectors' retainer screws.
Aug 24, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913v picture rotated 90 degrees
Please press Ctrl-Alt and your arrow keys until the image is straight!
Mar 10, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 710V Comes on for a second then shuts down
the fault is the backlight, Samsung has designed it as when one of the baklights are faulty the unit shuts down.
Sep 02, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Jan 08, 2008 | Samsung SyncMaster 913V 19" LCD Monitor
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
