Microsoft Xbox 360 Console Logo
Posted on Nov 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i get windows media center without a pc? - Microsoft Xbox 360 Console
Will Bokach
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Microsoft Expert 537 Answers
  • Posted on Nov 02, 2010
Will Bokach
Microsoft Expert
Level 2:
Prodigy:
Answers
537
Questions
Helped
90561
Points
698
No, unfortunately, you need windows media center on your pc to stream videos, music, and pictures from your pc to your Xbox. It kind of sucks I know, as windows media center isn't the most accurate of programs. Has a tendency to loose data. Also, since it is a windows platform, your Xbox will have issues playing certain types of media files. Hope this helps.
How do I reinstall media center on win 7 pro.
1.Type appwiz.cpl in Start menu search box and then hit enter to open Programs and Features window
2.In the left pane, click Turn Windows features on or off link.
3.Once the Windows Features window is opened, expand Media Features and then uncheck the box next to Windows Media Center.
4.Click Ok. You will see "Turning off Windows Media Center might affect other Windows features and program installed on your computer, including default settings. Do you want to continue?" message. ClickYes and then click Ok to start uninstalling Windows Media Center.
5.You will be asked to Reboot your computer. Restart to uninstall Media Center from your PC. If you want to install it again, open Windows Features window by repeating the steps given above.
6.Expand Media Features, and then check Windows Media Center option.
7.Click Ok to Start installing the feature. Done!
tip
How to make a Media center Shortcut.
Windows 7 Media center have multiple switches for customization.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen Examples: %windir%\ehome\ehshell.exe "/mcesuperbar://tv?live=true" – That will start Media Center in LiveTV mode
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK.
For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
on Feb 10, 2010 • Computers & Internet
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Need the window media center re-installed
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
1helpful
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
Windows XP Home Edition
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
Windows XP Professional
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
Windows XP Media Center Edition
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
How do i turn on the media center buttons?
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
1helpful
Media Centre - uninstall?
Here is the main features of Media Center.
Media Center.M View your photos in a cinematic slide show, browse your music collection by cover art, easily play DVDs, watch and record TV shows, download movies, and project your home videos.
Windows Media Center offers built-in support for archiving TV shows directly to video DVDs and a platform for content owners to deliver new online entertainment services and experiences.U For U.S.-based customers, Windows Media Center offers support for digital cable service, by means of a digital cable tuner.
Frankly speaking I'm using Windows 7 but never had the need of using media center.It cost huge on system resource when running,Even when you watch video it will load other features too when the Media Center start. you can uninstalled it without any worry.
here is the page link on how to disable and uninstalled Media center.why I am giving you this link is, it can't be uninstalled using windows same old add/remove program tools in control panel.
http://www.mydigitallife.info/2008/02/23/how-to-disable-uninstall-and-remove-windows-media-center-in-vista/
Have a very Happy New Year.
Flicker every 60 sec in Win Media Center TV mode
go to HP.com and look for the TV tuner upgrade. See if that solves your problem. Let me know
Thx
Media centre
if you have a TV card and antenna or cable hookup, yes.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
