most likely its the turn signal relay. which is under the hood. in the fuse box. also make sure ur running lights are working if they are connected to the turn signal.
Check the lamps first to see if both are good, do a wiggle test to see if the lamp's socket is good(sometimes they get too hot and the contacts spread open). Next check fuses for the running lights and break lights. If the running lights work on the front but not on the back then its not a fuse its a ground issue. Use a stick or another person to depress the break pedal to check for power at the plug that goes to the stop/running light lamp.
thereis three switches to check one is the muti function switch. the second is the headlight switch and third is the brake switch on the pedal.if not them check your ground and see if it is secured properly
FAN AND LIGHT DOES NOT WORK my
zephyr typhoon stopped working. Neither light not the fan come up. I am
sure there is power going into the unit. I turned on the light one day
, the light cam on and suddenly went away. From then even the fan
stopped working. any information on what happened is appreciated.
Thanks
