Question about Acer Aspire 5500 5570-2609 Laptop
Aspire 5500 power problems
  • Battery drains and then comp hibernates.
  • how doi set it for AC power
    Genius:
  • 2,028 Answers
Right click on the desktop, then click properties. Open the screen saver tab and you will see a box that reads power. You can adjust your power settings from there. Although it sounds to me like your battery may be wearing out and need replacing. If you're new settings don't work, try running it just on AC without the battery for a while and see if it does the same things.
Posted on Jun 17, 2008
WHEN I HAVE MY LAPTOP PLUGGED IN IT CHARGES BATTERY TO 40% THEN STOPS WHY'S THIS
Hi Tina,
Your battery needs a calibration, follow the instruction below to calibrate the battery.
  1. With Windows Vista, navigate to Control Panel > Performance and Maintenance > Power Options
  2. Click "Change Plan Settings".
  3. Set all tabs to "Never" underneath "On Battery" column.
  4. Click "Change advanced power settings".
  5. Set Sleep > Hibernate after to 0 or Never.
  6. Set Battery > Critical Battery Level to 0.
  7. Click on "OK", then "Save Changes".
This is the only time that we recommend taking the battery all the way down to zero percent. Unplug the ac adapter, and let the battery drain all the way down until the laptop shuts off. Then plug the AC adapter back in, and let it recharge to 100% or where it actually reaches. You may need to repeat the cycle 2-3 times before it actually reaches 100%.
Note: After the calibration is done, change the power options settings back to what it was as they will help you save power. Also, when a power source is available dont run the laptop on battery, it will increase the battery life.
Regards,
Shrey
Jun 02, 2011 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
My Acer 3000 Laptop seems to be 'frozen' in 'preparing to hibernate' screen, how can I fix this please?
Drain Flee power
Steps to do
· Disconnect AC adapter,
· Remove Battery
· Press and hold power button for 30 seconds.
· Reconnect adapter and battery
· Start your pc and go to safe mode and check power settings.
· Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Aug 09, 2010 | Acer Aspire 3000 Notebook
Hibernation mode
First thing to try is to remove the battery and disconnect the AC adapter. Press the power button for a full 10 seconds to drain residual power from the capacitors on the board. Give it 5 mins then put the AC adapter and battery back in and give it a try. You might also refine your hibernation settings - I had a 5000 which is similar and finally turned hibernation off. Also check for a pin switch that the lid pushes down when it closes to see if something is holding the switch down when the lid is raised. I dont remember if that model has a mechanical push switch or a magnetic. Magnetic shouldnt do it but mechanicals are very prone to getting stuck.
Jul 02, 2010 | Acer Aspire 3000 Notebook
Mouse pad been working fine, but now not working on acer aspire 5732Z i had for christmas. can i fix or will i have to return to shop?
hello, i have a suggestion for this kind of problem. Try to do a power drain. First you have to power off the computer, remove the battery and ac adapter and anything that is plugged on to your computer. Press and hold the power button for 15 seconds. Put the battery back and the ac adapter, try to power it on and test it. If still doesnt work try to uninstall and re install the driver for your mousepad. Hope this helps! goodluck!!!
Jun 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have 5573 which when pressed the start button shows indicator light for the moment but then goes off consequently laptop doesn't start. The product is Laptop Model Aspire 5573ZNWXMi having Intel pentium...
To isolate the problem do the following:
1. Drain the power from the system first by removing battery and ac adapter then press and hold power button for 10 seconds, put battery and ac adapter back and turn on computer.
2. If still having a problem, drain power again but this time turn on system with just the ac adapter.
3. If still have problem normally with this issue it might be caused by the rams so drain power from system again, locate the bay for the rams and reseat the rams. (do this step only if you are capable, if not get a help of someone who knows the job)
4. If still not turning on there might be a problem on the mainboard and you will need to get a local help to have the system check if the problem is still fixable but with this issues normally it's the whole mainboard that is being replaced or just the rams
Jun 03, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
No display on my acer aspire 4520
i will try my best
control panel display screen saver
then power
make sure your settings are all correct set stanby and sleep to never
click hibernate then remove check
then apply restart i hope this takes care of problem
if not let me know i just think you have a setting wrong somewhere.
does it do this on power or Ac battery or both
Jan 26, 2009 | Acer Aspire 3610 Notebook
Aspire 5500 power problems . -
There has been many problems with the svc pck 3. Mostly consisting of software conflicts that weren't there before the update. Uninstall svc pck 3 and see if that cures it.
Jun 18, 2008 | Acer Aspire 5500 5570-4421 Laptop
My acer is plugged it but will not charge
if the adapter charge the battery but cant keep the lappy power up thereis something rong with your motherboard. to test take the battery out plug adapter in turn lappy on. if it does not power on motherboard problem
Apr 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
