Question about Generic Memory PCI USB and Firewire Combo Card (sd-cb5271b-4e6i)
I/O ERROR DEVICE MSG
I BOUGHT A USB CARD READER/WRITER & WHEN I PLUGGED IT IN & TRY TO OPEN THE (F:) DRIVE WHERE IT'S LOCATED A MSG POPS UP "The request could not be performed because of an I/O Error device"..what is that suppose to mean?Is the problem caused by my micro memory card or w/ the USB card reaedr i just bought?
    Problem Solver:
  • 6 Answers
I had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!..make sure the lock is off!
Posted on Jul 28, 2009
Kodak how to use
These memory card are usually USB connections so you should just need to insert it in a USB slot and then insert the memory card. You may find that your computer needs to have the 'Reader' drivers installed. This usually happens automatically when you first try to use the 'Reader' Have you tried locating the USB drive to activate it. Insert the Reader with a memory card in it go into My Computer find the USB drive and double click on it
Aug 13, 2014 | Kodak A250 50-in-1 Memory Card...
Msre206-66 reader/writer
Try to use different USB port. If you still have the same problem, try a different computer because maybe the USB port is not compatible. It might be a USB 1.1. Your writer could be requiring USB 2.0
Aug 31, 2008 | Unitech MSR 206-33 (msr206-33) Magnetic...
I need to download my pictures from my camera into my computer please help me thank you
There are two possible ways to go about transferring your photos from a digital camera onto your computer. Please note that the given solutions both assume you are running Microsoft Windows XP or newer as the steps may be slightly different on a Macintosh or earlier versions of Windows.
Option 1: USB Transfer Cable. Most digital cameras come packaged with a cable that has a standard USB jack on one end, and a smaller plug on the other end. Locate the appropriate hole on your camera that the smaller plug (Micro-usb) will fit into. There is a decent chance this hole will be covered by a silicone or rubber flap, so that should help you find it. Plug the full size USB plug into your computer and a pop-up should appear on your screen asking you what you want to do with the new storage device. Scroll to the last option "Open a folder to view the files" and double-click. From there, simply copy and paste photos to the desired directory on your computer.
Please note: If you do not receive the pop-up, simply navigate to My Computer, and look for a device that is not your hard drive (Typically C:\) or your CD\DVD drive (Typically D:\) and double click to open it up. The pictures should be located in a folder named DCIM, but it varies by manufacturer so you may have to check a few folders to find them.
Option 2: Memory Card Reader. Alternatively, if your computer has a memory card reader you can simply remove the memory card from the camera and plug it into an appropriate slot in the card reader. Most memory cards are located right next to the battery storage on modern cameras. Pictures of typical card readers for a desktop (fig. 1) and laptop (fig. 2) are provided below. Once the memory card has been inserted, you should see a pop-up asking what you want to do with the new storage device. Scroll to the last option "Open a folder to view the files" and double-click. From there, simply copy and paste photos to the desired directory on your computer.
Jun 10, 2011 | Computers & Internet
How do i get my 2gb memory card to work on my samsung e900
Hi - Sometimes devices are finicky about which SD cards they work with. I suggest you try a different brand card. Be sure to purchase it where they have an easy return policy just in case. The phone definitely supports two GB cards.
Luckily two GB cards are pretty cheap and it's always good to have a spare.
Good Luck, Mikeywaf
Mar 01, 2011 | Samsung SGH-E900 Cellular Phone
I just bought a SanDisk 4GB microSDHC memory card and adapter. I saved my photos from my LG XENON phone to this microSDHC card but can not download them. I have a mac desktop computer running Mac OS X...
You must use a SDHC compatible reader/writer, please check if the readers of your Mac and printer can handle this kind of SD, if they don't, you could use a USB SDHC compatible reader.
Feb 20, 2011 | SanDisk 4GB microSDHC Memory Card
I have a pallette 2.0 i purchashed with babylock esante ese but the computer is newer and has vista. we bought a new usb cord but when we try to load program it says card writer is not connected. can you...
It sounds like you need to update the device driver for you card reader. You can go to Baby Lock USA web page and do a search for driver updates. Also the USB cord for the reader/writer card is specific for this device so don't throw it away until you try updating the driver for your particular Windows version.
Sep 02, 2010 | Baby Lock Esante
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Nov 19, 2009 | Electronics - Others
Bought myself a 14 in 1 card reader to read my new 16gb SDHC card, however, when I try to format or transfer anything onto my new SDHC card, it gives me the error that it is write protected, even though it...
Are you using software that came with the reader? Maybe that is the problem. Are the correct drivers installed? Check the device manager and make sure it does not show a problem device. Are you using my computer and clicking on the removable device? Does the card work ok in other computers or devices? Is your computer only USB 1.0 and the card reader requres USB 2.0? Are the USB 2.0 drivers properly installed on your computer? Try removing the software and drivers, re-boot, and just install the drivers and not the software.
Sep 10, 2009 | Electronics - Others
Husqvarna 3D and d-card reader/writer software.
Ok I just magically fixed my d-card reader, maybe this will work for everyone else as well: It seems really simple, but I unplugged the d-card reader from the USB port, and plugged it back in. A window popped up saying "New hardware found" and asked if I wanted to install the new hardware. With the install disc in the drive, I clicked ok for it to install and it just did it and it works now. I didn't open the install program on the cd (at which point before it told me I didn't have the right customizing software and it couldn't be installed), I just did it this way instead. It was quick and easy... give it a try and good luck!
Mar 11, 2008 | Computers & Internet
Write protected error using Sandisk card in Digital Concepts CR-75 Reader
Try a different reader if you can - laptops comes with an SD reader sometimes. Or take it to a computer store or possibly radio shack would have one open to test.
Or just replace the card - 1gb cards are $20 now.
Dec 19, 2007 | Electronics - Others
Generic Memory PCI USB and Firewire Combo Card (sd-cb5271b-4e6i) Logo
83 people viewed this question
Top Generic Memory Televison & Video Experts
Are you a Generic Memory Televison and Video Expert? Answer questions, earn points and help others
