Question about Brother MFC 9700 All-In-One Laser Printer
White paper no longer white
Using white paper to print, the white paper came out in a shad of light gray.
You are probably getting low on toner. Your printer also might just need a little cleaning. I would open up the front of the printer and take out the toner/drum. Wipe off the edge of the toner cartridge with a dry cloth to remove excess toner. Replace the toner cartridge and see if this works!
Posted on Jul 03, 2008
Thermal printer very light print image
I forgive you did put this between the motherboards. Should be in Printers.
I could not find anything in the manual, that says this printer could print light characters. (or any gradation) this is emulated with spacing between dots. So I think :
1 The trminal array, that heats the paper has a voltage a bit to low (very unlikely)
2 the paper is not ok. If it is the same paper you always have used, are you sure it was stored correct. Not to moist, not to long?
Did you buy or get paper from another factory?
When you heat the paper, does it turn black anyway? Or does it stay gray (light gray). I don't know at what temperature the paper should change to black. Can't find this in the manual.
Nov 10, 2013 | Computers & Internet
Shaded area on white scanned papers
Go through the printer properties (control panel/printers/right clicking on the printer, and click on properties). Then go to the maintenance tab and click on clean print heads.
Apr 30, 2012 | Fujitsu fi-6130 Flatbed Scanner
How do i only print black n white pics
Hello!1. Please press Ctrl + P after opening your picture.2. Go to Set up/Advance.3. Select your paper.4. Select Gray scale on the top of your paper size.5. Now press print. Your picture will be print with black & white... Good luck
Jun 09, 2011 | Canon iP2700 Inkjet Photo Printer
Hp laserjet 3055. after printing labels, a few at a time, over and over. The label paper is no longer white, it is gray. The label paper picks up dirt from the printer.
Labels are a problem, as they really kill the printer, if they come off. It sounds like your issue may be that you need LASER labels, which are less affected by the temperature of the laser cure process.
Apr 01, 2011 | HP LaserJet 3055 All-In-One Printer
Unwanted gray stripes on paper
Printer needs a good clean and service.
Toner particles have probably split onto the fuser drum or has been contaminated by previously printed paper losing some toner.
As the particles get re-heated, they become waxy and smear around the drums and rollers.
For stripping and cleaning procedure, check the FIXYA manuals and tips, searching for your model, or similar one, or try a manuals download website and enter your make & model.
HP may also have the info.
You'll probably need a service manual rather than the user manual.
Nov 20, 2017 | HP LaserJet 5si mopier Printer
Printer cant print in black and white
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Mar 03, 2009 | Canon MP610 Photo All-In-One Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
My HP 2900n is turning the white paper gray on everything. How do you clean the roller?
Check the Density settings first and might as well check Brightness and Contrast.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Brother MFC 9700 All-In-One Laser Printer Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
