Question about HP Pavilion dv6000z Notebook
Mexican keyboard we changed the keyboard on our HPdv6000 laptop to the mecican version, and now we can not find the @ key. It is no longer with the 2- can anybody help please!!!
  • Anonymous Jan 04, 2009
    how to work the at in a mexican keyboard
  • 242 Answers
You should use Ctrl + Alt + Q to get an @.
Posted on Jun 12, 2008
Press alt+2 it should work
Posted on Dec 12, 2008
HP 2000-208CA Keyboard Some Keys Don't work
I had a similar problem after replacing a damaged keyboard, turned out that the ribbon cable kept pulling slightly from its socket each time i replaced the keyboard, try lifting the keyboard gently and check that the ribbon cable is fully inserted correctly.
Apr 06, 2013 | Computers & Internet
Shortcuts have locked up on my pc
Conflicting Extensions
Add-ons, also called plug-ins or extensions, are mini-applications that attach themselves to independent software and add extra capabilities to the program.
Extensions can change a browser's interface, alter the behavior of existing operations, add new functions or install in-browser support for programs like Shockwave Flash or Adobe Reader.
Because these extensions make changes to the overall operation of a browser, they can also affect the shortcut keys.
Most browsers offer an option to run the application with add-ons disabled; if the shortcut keys work when extensions are turned off, one of the add-ons is at fault.
Key Reassignments
Programs like MapKeyboard, SharpKeys and KeyTweak can reassign the functions of each key on the laptop keyboard.
If the computer is running a non standard keyboard layout, certain keys might not behave or respond normally.
For example, if the "Ctrl" key has been disabled or is set to work like "Shift," shortcut keys won't work as expected because the keyboard is no longer using its default mapping.
If the keyboard layout has been changed in the Dell laptop, the registry will contain a Scancode Map entry in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout or the language bar will show a keyboard language different from the default ("English (United States)," or "EN," for Dell laptops purchased in the U.S.).
Virus Infection
Malicious software can affect the function of peripheral components like the keyboard and mouse.
If the keyboard is exhibiting strange behavior for example, if certain keys do not respond or if keys output unexpected letters a virus is most likely the cause.
Running an anti malware software from within Safe Mode accessed by pressing "F8" on the Dell logo screen should remove any viruses interfering with keyboard response.
Browser Software
Upgrading or downgrading a browser on the PC can affect the Internet shortcut keys associated with that program, especially if the version removes a function that was once associated with a particular keyboard combination.
Alternatively, if you've switched to another browser, you might find that certain shortcuts that worked in the previous browser don't work in the new one.
For example, while "Shift-F10" opens a context menu in Internet Explorer, the same keyboard combination does nothing in Mozilla Firefox.
Hope this helps.
Nov 20, 2012 | ASUS Computers & Internet
How do i type @ on a acer one spanish keyboard
Try Alt+2
If not, then Alt+Q
(Spain Spanish keyboard, it's Alt+2. Mexican and Colombian Spanish keyboards use Alt+Q)
May 02, 2011 | Computers & Internet
How do i change the speed of the type on the keyboard
Sounds like you have sticky keys enabled..follow these steps:
Step 1. Click Start, select Control Panel
Step 2. Switch to Classic View if not in Classic View Already
Step 3. Open Accessibility Options
Step 4. Click on the Keyboard tab, and clear the "Use Sticky Keys" check box.
Step 5. Click Ok, and Ok again to exit.
Apr 20, 2010 | HP Pavilion dv8000t Notebook
How can i make a forward slash on a mexican keyboard. on an american keyboard there is useually one symbol per number on the top keys so you onle have to press shift then the nuber to get the symblol...
On these keyboards, the non colored symbols are typed by holding down the shift key and tapping the symbol. If you want to type the colored key, then you have to hold down the Alt Gr key and tap the colored symbol key.
Jan 13, 2010 | HP Pavilion dv6000z Notebook
I don't know how to write spanish caracter in my laptop it is an acer5610
ñññññññññññññññññññññññññññ :P
U need to change ur keyboard configuration, go to: Control Panel Clock, Language and Region Change keyboards or other input methods Click at Change Keyboards Add an spanish language (idk which one u will prefer, i use mexican) Then change ur default keyboard to it.
Ahora eso es si quieres cambiar tu idioma principal a español, if u dont and just need a character, use the ASCII code:
Press and hold ALT + 164 for ñ and 165 for ñ
Nov 03, 2009 | Acer Aspire 5610-4648 Notebook
Four keys on keyboard no longer work
try cleaning the keys,remove from keyboard.use solvent alcohol to clean membrane
May 03, 2009 | Computers & Internet
Need to purchase
yes of course u can change just follow these methods
First, you need to install a Spanish keyboard, and turn on the key combo to
switch.
Go to Control Panel, Clock Language and Region.
Then click on "Change Keyboard or other Input method". The Regional and
Language Options dialogue will appear.
Click on the Keyboards and Languages tab. The Text Services and Input
Languages dialogue will appear.
Under Installed Services, press the Add button, and select an appropriate
Spanish keyboard (eg Spain, Mexico, US etc).
Press Ok to add the selected Keyboard.
Now click the Advanced Key Settings tab, of the Text Services and Input
Languages dialogue. Select a key combination, to alternate between English
and Spanish keyboards (Left-Alt, Shift, by default)
Press Ok to accept changes and dismiss the dialogue.
Your Spanish keyboard should now be ready to use, once you press the
Alt-Shift combo.
this is just the display language settings for full conversion you cannot do u have to buy a spanish version or ask your laptop assembler to put spanish version of vista hope so your problem solves with this solution
May 09, 2008 | Microsoft Windows XP Professional With...
Keyboard problem
Information about computer keyboards Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
Information about the AT and PS/2 port 1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
Device Manager information and help Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
Dec 19, 2007 | Acer Aspire 3680 Laptop
HP Pavilion dv6000z Notebook Logo
679 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
