Magic Chef Washing Machine
Washing machine keeps filling with water to overflow and won't go to next stage.
  • Anonymous Mar 27, 2014
    pum washing
  • 868 Answers
You have a air leak in either the pressure hose or the pressure switch itself.
Posted on Jun 12, 2008
I have a GE Adora top-load washing machine. The washer fills up and overflows with water on all settings. Any ideas why?
  • You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
Dec 27, 2016 | GE Washing Machines
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
Cold water won"t fill
check the filter... make sure the line is not kinked...
Aug 08, 2012 | Magic Chef CAV2000 Top Load Washer
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
Washing machine overflowing
Sounds like the water level sensing sub-system is malfunctioning. If you want to pursue this further, let me know.
Apr 29, 2009 | Siemens WFXD8400UC Front Load Washer
Magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Oct 23, 2008 | Washing Machines
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
