Cars & Trucks Logo
Posted on Nov 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't seem to shift in forth gear. Can't find it & the original shift stick has been replced. Is 4th gear all the up to the right or doow on the right? Please help
911 doctor
Level 2:
Sergeant:
  • Porsche Expert 330 Answers
  • Posted on Dec 20, 2010
911 doctor
Porsche Expert
Level 2:
Sergeant:
Answers
330
Questions
7
Helped
88985
Points
501
Hello there
you should look under the cover behind the seat on the floor.There are 4 phillips screws remove the cover and there is a shifter coupler.Look if it has a play (the plastic is worn out) or the little 3mm allen screw bolt is loose.If ok look at the shifter tower bushing.
let me know
[email protected]
2008 Astra sticks in 4th gear why?
There could be several reasons why a 2008 Astra may become stuck in 4th gear. Here are a few potential causes:
1. Transmission issues: A problem with the transmission itself, such as a damaged gear or a malfunctioning shift solenoid, can cause the vehicle to remain stuck in a particular gear.
2. Clutch problems: If there is a problem with the clutch system, such as a worn clutch disc or a faulty release bearing, it can prevent proper gear engagement and cause the vehicle to stay in 4th gear.
3. Shift linkage or cables: Issues with the shift linkage or cables that connect the gear shift lever to the transmission can result in difficulty changing gears, including becoming stuck in 4th gear.
4. Hydraulic issues: Problems with the hydraulic system, such as low fluid levels, leaks, or a malfunctioning clutch master or slave cylinder, can affect the proper operation of the clutch and transmission, potentially causing gear-related issues.
It is important to have a qualified mechanic inspect and diagnose the specific cause of the problem. They can perform a detailed diagnostic procedure, check for error codes in the vehicle's computer system, and conduct necessary tests to identify and resolve the issue with the 4th gear sticking.
Isuzu wil not go to 4th gear
forth gear is not a gear as such but a straight coupling of the input and out put shafts
check the gear shift lever for obstructions at the turret or under the mat
Check the drain plug magnet for metal
,3rd and 4th forth use the same selector rail and if there is a problem with the 4th selector fork there would be no chance of selection any other gear as it would lock the box
it is possible that the syncro ring assembly has failed preventing the movement of the dog to engage the teeth in which case it is box out for repair
3answers
Hyundai accent transmission problems
the M/t box has 4th
no a/t here as 4th period
so must be manual transmission
real photo blow is A/t BOX.
START A POST MY CAR IS STICK SHIFT
AND WIN.
Gearbox cables 1989 model
You should look for the clips and rubber bushing at end of the cables, at shift lever and at the transmission. Buy a repair kit and replace them. That will take care of the problem. Good luck.
Why won't my 1997 ford aspire shift into 3rd or5th
it could be the valve body sticking, or worn clutch plates in the 3 & 4th gear planetary drum, or 3rd &4th gear solenoid is bad
I have a 1987 Accord LX 4 dr. When driving at approximately between 55 to 60 mph the transmission shifts back and forth between 3rd and 4th gear with the slightest acceleration. It seems to me it's doing...
Depends on the throttle position, there is a adjustment for that transmission. I would suggest someone who has Honda experience, like a dealer.
2helpful
97 venture 4 speed electronic transmission not shifting into 4th
4th clutch hub splines are stripped off. GM didn't harden the splines until 2004 or so so the early model gradually wear to the point where they are so thin they strip off - and then, no 4th gear
Tranny Lock
syncro problem
low on oil
check stick shift adjustments
shift stick bushes or a cable problem
check engine mounts
gearbox, fork or clutch worn
Top Porsche Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Porsche Expert? Answer questions, earn points and help others
