Question about Xerox 8830 Copier
Xc 830 problems
I have 2 xc 830's,the problem with one is printing is ascue,it will not print correctly in line aways at slight angle.is there an adjustment?the problem with other one is it prints white background grey and sometimes darker,have set to default,tried everything,was going to add to developer&toner could this solve the problem,or could fuser be running too hot?
What is the solution when appear the word "idle" in the screen of my 8830 xerox?
Posted on Jan 09, 2009
    Scholar:
  • 53 Answers
Why not take the developer and drum units out of the skew copy one and put them in the other? At least that will tell you if dev/drum/toner is the problem.......
Skew copies on the other...look for torn corners of paper tight in the end of feed chutes etc, sometimes clearing a jam will leave a bit in there enough to slow down that side of the feed.If you can see any rollers make sure they are closed and parallel to each other and clean...
Posted on Jun 19, 2008
I can't seem to install my ink cartridge correctly. Do you have a picture demonstration on how to do this? I continue getting an error message.
Installing the print cartridges Follow the instructions below to install the print cartridges: caution.png CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  1. Remove the print cartridge from its packaging and carefully remove the plastic tape from the copper strip. Figure 2: Removing the plastic tapec00109809.jpg
  2. With the power on, open the printer's top cover. The cradle moves to the center of the printer.
  3. Hold the print cartridge so that the copper strip is on the bottom. Figure 3: Holding the print cartridgec00109811.jpg
  4. Insert the cartridge into the cradle at a slight upward angle until you feel resistance. Figure 4: Inserting the print cartridgec00109813.jpg
  5. Firmly push the cartridge into the cradle. You will hear a snapping sound when the print cartridge is correctly positioned. The print cartridge fits securely in its cradle. Figure 5: Print cartridge in correct positionc00109815.jpg
  6. Close the top cover.
  7. Calibrate the printer for optimum print quality.
    Best of luck!
Sep 06, 2011 | HP Office Equipment & Supplies
How do i change the cartridges of hp psc 1215
1. Turn on the unit, then open the print cartridge access door by lowering the handle. -- The print carriage moves to the center of the unit.ionstorm_0.jpg
2. After the carriage stops moving, push down on the print cartridge to release it, and then toward you out of its slot.
3. Remove the new print cartridge from its packaging and, being careful to touch only the bright pink plastic tab, gently remove the plastic tape to uncover the ink nozzles.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge immediately to prevent the ink from drying in the nozzles.
4. Push the new print cartridge into the appropriate slot at a slight angle until it clicks into place.
Caution!
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
The tri-color print cartridge goes on the left and the black cartridge goes on the right.
5. Close the print cartridge access door.
May 06, 2011 | HP PSC 1215 All-In-One InkJet Printer
See below: Also is a link the the manual for your unit the maunal has pictures: Page 62 of the manual list the procedure. (page 72 in the adobe file)
Manual
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
Note: It is normal to see ink buildup in the print cartridge slots.
Print-carriage
access door
hp officejet 5500 series
chapter 8
64 maintain your hp officejet
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the pink tape by using the pull
tab.
4 Hold the black print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
Note: You must install both print cartridges in order for your HP Officejet to
work.
reference guide
65
6 Close the print-carriage access door. Within a few minutes, a print
cartridge alignment page prints.
Feb 25, 2011 | HP Officejet 5510 All-In-One Thermal...
Media problem during printing
If the media is coimng out straight, then look at the cutter mounting.
If the cutter is slightly off angle then it can be corrected on the mounting beneath the right lower side, and the lft upper (head latch) side.
Try printing a barcode or straight line of print on the top and bottom of the label. Look at the print in relation to the cut.
If it is off , it may also be the printhead azimuth.(angle of the head in relation to the platen roller(roller beneath the head).
There is an adjustment fo tthe head to suare it up to the platen.
Jan 27, 2010 | Zebra 105SL Thermal Label Printer
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
It must slide in at a upward slight angle.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printing has started coming out at a slight angle
Please click here and folow the instructions to resolve the issue.
May 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
HP D135 printed lines are angled slightly downwards left-to-right
twobells i have almost the same problem with the hp photosmart c4599 i have had no luck either
Jan 01, 2009 | HP OfficeJet D135 All-In-One InkJet...
Epson Stylus Photo 830 Only printing first 2 inches of page
try uninstall your printer and then install it again.....
Oct 25, 2007 | Epson Stylus Photo 830 InkJet Printer
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
