Question about Sony Cyber-Shot DSC-S75 Digital Camera
Sony memory stick pro duo format error
When I insert my memory stick pro duo to my digital camera "format error" appeared blinking on the screen
  • 3 more comments
  • gicookie Jun 14, 2008
    When insert Memory stick duo in Sony DSC S75,
    The camera dose not recognise memory stick.
    All using the DUO STICK ADAPTERS
    But the memory stick works fine (read and write ) when connected to a PC stick reader.
    I wish I knew the answer..
    I have tried the 1Gig stick from Curries (they informed me the addapter is only for reading the stick !!! ,
    Jessop inform me my camera is old model and only can use 512Mb or less !!!,
    Boots 512 dose not work or even Boots own brand 256Mb (Hear I must thank the Boots assistant for trying different ones).
  • Anonymous Jul 01, 2008
    same
  • julie2008 Jul 31, 2008
    When i tried downloading pictures from 2 GM Magicgate Produo SONY memory card, it says format error.
    Tried with card reader, but same error.
    Tried in the photo studio but doesn't recognize the disk
    How do I download the pictures. Card was full.
  • bangbang_lee Aug 15, 2008
    I have the same problem with my Sony cyber-shot DSC-S700 when i put my memory stick PRO DUO it flash always format error.. i tried already to fixed it (Formatted) but still the same problem... what is the best solution? Is anyone knows? Please help me? thanks!
  • Anonymous Mar 25, 2014
    When the memory stick pro is inserted into the camera, it just flops back and forward as if its the wrong size. I also tried the memory pro duo and it does the same.
Memory stick is bad or damage. go and buy another ............
Posted on Jun 14, 2012
When i turn my camra on its does nothing it has a black screen and it don't turn off then when i take the memory stick out it works and turns off with no problem
Posted on Sep 21, 2008
  • 10,594 Answers
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Posted on Jun 12, 2008
When you turn on the camera, message Memory stick error appears. Camera works fine with internal memory but not when using sony memory stick PRO DUO
Try to format memory stick through camera menu to solve this problem and if camera wont allow to format then try/ replace memory stick as this PRO DUO could be defective.
If another memory stick gives same problem then memory stick slot connectors could be bad and visual check by local camera repair shop is required.
Thanks.
Feb 27, 2011 | Sony Cameras
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
When i turn on my camera it appears "error formating memory stick"
I inserted adapter and memory stick in my sony cyber shoot camera and keep getting format error. How do I format the memory stick
Jun 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Well alot of the time there is a issue with the formating that the camera does on the stick and also when formating it on the computer it formats it another way as well. some in FAT and some in FAT32 this is ushally a error for the most part I would definatly plug your duo stick into a card reader and then go to my computer and the find the drive that the stick is in and right click on it and go to properties and do a error check on the stick to make sure that there is no errors. and if you can defragment after the scan then by all means do it and then format the card and try it and hopefully it will work out to your advantage.
*note this problem seems to only happen with the non branded duo sticks not the sony branded ones.*
Aug 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Mavica MVC-FD2000 can't read memory stick...
THE CARD PROBLBLY HAS NOT BEEN FORMATTED...ARE YOU SURE IT IS A MEMORY STICK PRO "DUO" THERE ARE DIFFERNT KINDS OF MEMORY STICKS (PRO DUO, PRO, QUAL, ETC.)
Feb 21, 2008 | Sony Mavica MVC-FD100 Digital Camera
Sony Cyber-Shot DSC-S75 Digital Camera Logo
2,158 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
