Question about Dryers
Dryer has Dents in Stainless Steel Drum!
Dryer has Dents like when hit by Hailstorm! In the Stainless Steel Drum since using DRYER MAX Dryer Balls 2 times and Dryer is Brand New!
  • 868 Answers
Hmmmmmmmmmm,never tested hailstorm damage,but..........if you say its brand new,let me fill you in on something here.WARRANTY'S WILL NOT INCLUDE THE DRYER TUB IN COVERAGE ,unless the tub supports (rollers/bearings)have failed.There has to be a mechanical failure that causes the tubs problem. Max balls are not included.
Hope I helped you !!! Please rate this !!
Posted on Jun 12, 2008
How do you reset the touch button controler. Dryer will not shut off.
Try removing power. Unplugging or circuit breaker. Then plugging back in. See if it helps. Good luck.
Jan 29, 2017 | LG DLEY1701V DLEY1701V 7.3 cu. ft....
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
I have a small dent in my stainless steel refrigerator. I've tried a plunger and the blow dryer and dry ice trick any other ideas?
Because it is stainless steel it is not likely that it will come out the compressed air and blow dryer are you best bet but it is unlikely that it will come out
Mar 05, 2011 | Microwave Ovens
Dryer makes a thumping sound with or without anything in it
Look for a crack in the seam, where the stainless steel drum is welded together, either at the front or back edge of the drum. If weld is cracked, replace drum.
Jan 31, 2011 | LG D5966 Gas Dryer
My LG DLE5977W's drum will not turn, and makes hmmmm when I hit the start button. I can turn the drum manually; power is good as it lights up; lint is cleaned out also;
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | LG DLE5977 Stainless Steel Electric Dryer
I have small dents in the stainless doors. How do
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
It is more cost effective to replace panels than remove the dents. We can remove scratches but not dents, use DeBruce Polish for maintenance.
Dec 31, 2009 | LG LFX25960 Titanium Bottom Freezer French...
Maytag Neptune Electric Dryer Broken Drum
look in your owners manuel and see if the drum is covered.
Jun 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
DRYER MAX Dryer Balls Dents all over Stainless Steel Drum of New Dryer??
if the dings are inside the drum and they look like someone took a hammer and hit the inside of the drum then it's what you put in it but if the dings are comming enward twards you then there's something hitting it from outside the drum. and if that be the case call the store were you got it and have someone come out that is if it has a warnnity and if the dings go out twards the dryer then contact the person who sold you the dyer max balls and tell them you won't payed for a new dryer you may have to take them to court and then again you will have to prove that the balls did it
Jun 13, 2008 | Dryers
Dryers Logo
134 people viewed this question
Top Dryers Experts
