Question about ASI CL51-15 Notebook
Tosiba Satellite A105-S2716
When I turn on my notebook it starts up to windows, then the screen starts to flicker then goes blank. Any ideas on what is wrong and what I need to do to fix it
  • 70 Answers
Try to use ENABLE VGA MODE when booting Windows.
1. Restart computer.
2. Press F8 continuously untill selection tabs appear.
3. Select ENABLE VGA MODE.
If this procedure works, adjust the Monitor setting or display setting on your control panel to lower settings.
If this procedure works, please spare a little time to rate my solution.
-mrsolution
Posted on Jun 12, 2008
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
I have a Toshiba Satellite A105-S2716 its about 3 years old and I have tried all extended life batteries but they don't charge.
Toshiba had issued a bulletin and a BIOS upgrade (version 2.0) to address the battery not charging/working issue (it's a bug in the system is what it is). Make sure that's done before contemplating any hardware changes or repairs.
Aug 22, 2011 | Toshiba Satellite A105-S2716 Notebook
Are all Satellite A105 15.4" screens the same? I
The LCD assembly will have a part number either on a paper sticker or printed on some empty real estate. Check for one that matches the structure of part number(s) listed on eBay.
You can start with the link below:
Toshiba Satellite A105 LCDs
Aug 07, 2011 | Toshiba Satellite A105-S2716 Notebook
How do i get toshiba satellite A105-S2716 Drivers to install?
Here is the site to download the driver...
http://www.drivershq.com/drivers/Toshiba/Satellite/A105-S2716/4183/9941/10714/Drivers.aspx
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 16, 2010 | Toshiba Satellite A105 Notebook
How to open a Toshiba A105-S2716 Laptop
remove all bottom screws, pull apart buttom cover, you will have access to fan which should have a couple screws and wire clip holding it all together.
Sep 15, 2009 | Toshiba Satellite A105 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
I have a satellite a105 s2716 and the lcd only works when in dual display mode... also seems to be a conflict with using dual displays, resulting in reboot cycle
Hi, the conflict that your equipment presents does not refer to the driver that this installing, refers to a fault of hardware which does not allow that the card of video give image to the LCD, and by the same situation when forza the video the equipment it is restarted, the solution to your problem is to replace the card of video.
Dec 05, 2008 | Toshiba Satellite A105-S4004 Notebook
A105-s2716
The problem with the LCD screen , if the external display is working fine. The LCD needs a replacement. The same thing happened on my Dell and we had to replace the Lcd. The same can occur because the LCD cable gets damaged when you open or close the LCD
Thanks
Proton
Aug 02, 2008 | Toshiba Satellite A105 Notebook
LCD monitor problem
What you described sounds like a loose LCD cable inside. Does it flicker or have video distortion when it's moved?
Jun 27, 2007 | Toshiba Satellite A105-S2716 Notebook
Computers & Internet Logo
73 people viewed this question
Top ASI Computers & Internet Experts
 Russ Hill
Russ Hill
Are you an ASI Computer and Internet Expert? Answer questions, earn points and help others
