Question about ASUS A7V400-MX Motherboard
Memory problem hi there ,i have a problem i installed one module 1gb ddr 400 (a data) and the pc won't boot ,it keeps restarting.now i have 2*256 ddr 400 one veritech and one princeton and in works fine.i've tried combining them with no result.Maybe you could help me ,are there any bios settings i should change?   tks
  • jonndoedanie Jun 12, 2008
    how can u tell the timings in bios for my memory?i have
    dram timing =166 (133,166)
    dram cas latency =2.5 (1.5 2 2,5 3)
    bank interleave=disabled(2 bank/4bank)
    precharge to active(trp)=5t (2t,3t,4t,5t)
    active to precharge(tras)=7t (6t,7t,8t,9t)
    active to cmd(trcd)=5t (2t,3t,4t,5t)
    dram burst length =4 (8)
    dram command rate=2t (1t 2t)
    write recovery time=3t (2t 3t)
    tWTR=2t (1t,2t)
    i tried settting to 166 manually and no result.Can u tell me what of these settings i should change?as they are now are working perfect with my 2*256 ddr 400
  • 70 Answers
Be sure that the 1GB DDR400 you've just installed is Working Perfectly, because sometimes if Memory is faulty then it will cause the computer to keep restarting, also check the specification of your motherboard if its support single stick of 1GB DDR400.
If this solves your problems, please spare a little time to rate my solutions. Thanks.
-mrsolution
Posted on Jun 12, 2008
  • 871 Answers
Well
you could check the timings in the bios for your memory. if they match. you could at least try to set it to 133 and set it to manual and not by speed. give it a try.
Memory problem
When you install your RAM you should make sure it is the same spec as that you removed. I would suggest that you use 2 512 mb sticks as it will be faster than a single 1gb stick. Make sure you buy DDR 400 RAM You need to look for PC3200 RAM.
Apr 10, 2013 | Computers & Internet
I want tobuy 1gb memory card for my ms 6787 ver2.. what is the specific type of memory card is the best for my board (1gb or 512mb only)
For this particular motherboard, you need a 184-pin DDR SDRAM DDR 266 (PC 2100) memory module. These can be found in sizes ranging from 256MB to 1GB. There are several places that these could be found on the internet. Pricing for a 1GB module seems to be around $44 or $45 USD currently.
The MS-6787 supports a maximum of 2GB of RAM (1GB in each DIMM slot).
Hope this is helpful!
May 09, 2011 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
I am trying to install two 1gb ddr pc2-4200u ram into my Dell Dimension E310 desktop. I currently have two slots, I removed the original 256mb stick to make room for my two 1gb sticks. When I boot the...
I belive the problem is caused due to non compatible memory being installed . According the Dell documentation the memory specification is as under
333- and 400-MHz DDR SDRAM
1Gb Non-ECC on each slot.
Just check the speed of the memory you are trying to connect.
Dell Documentation
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell Dimension 3000 PC Desktop
Pc keeps rebooting
Try re-installing the operating system. It is possible it possible OS is not installed properly. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Computers & Internet
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
Adding a second 1GB pc3200 DDR ram!
Are you sure memory is same (type and make) as they can have different timings and speeds.
remove 2nd memory module see if computer starts if it does i believe memory module could be faulty
Jul 23, 2008 | Asrock M266A Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
ASUS A7V400-MX Motherboard Logo
62 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
