Question about Samsung CLP 300 Laser Printer
Re : paper jam
I tried to print an iron-on transfer on my samsung clp 300 but now I have a paper jam. I tried to remove it but the paper got torn and now it looks like I would have to dismantle the whole printer to get the other piece out.
Is there an easier way?
  • regibiz Jun 12, 2008
    Thank you for the quick response...but it looks like I have to buy another one. I notice there is smoke coming out when I turn it on.
  • keithminty Jan 08, 2009
    same problem. what settings does this printer need to be on for transfer paper. pls help
  • 369 Answers
Posted on Jun 12, 2008
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
Feb 15, 2011 | Samsung CLP 300 Laser Printer
It wont print, says paper jam, yet there is no paper stuck anywhere? any suggestions?
Try removing the cartridges and drum and clean the big grey roller as this picks up paper and if not it will show a paper jam without paper being in the machine!
Good Luck!
Jan 17, 2011 | Samsung CLP 300 Laser Printer
Samsung clp 300 starts to feed paper but stops feeding (jams?) midway
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 05, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
Paper will not feed
Check if a piece of paper is still left from the paper jam. Sometimes pieces of paper get stuck behind the feeder roller if the paper is torn while removing the jammed paper
May 23, 2009 | Samsung CLP 300 Laser Printer
Samsung clp-300 printing
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
216 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
