Question about Video Cameras
Jvc camcorder gr-ax700u
Everything is fine, except viewfinder is blank
  • redrooster Jun 12, 2008
    is that it ? no schematic to see where loose connector is! or what settings? shouldnt the viewfinder just be on, like every other camera when you turn it on?hows about a bit of detail instead of stateing the bleeding obvious.like take off sidepanel,locate blue connector next to ect.....thanks for nothing so far
  • Video Cameras Master
  • 13,433 Answers
It is either a loose connector or a wrong setting.
Posted on Jun 12, 2008
  • 3 more comments
  • Ekse Jun 12, 2008
    if you have warranty I would recommend you contact your dealer first, to get it repaired for free.
    I do not own a service manual for your device, But I've located possible usefull documents for sale
    https://www.manualsparadise.com/ShowProd...
    The closest manual for your device available from JVC is a brother model 710
    at this address
    http://books.jvcservice.com/Download/107...
    IF you try connecting the camcorder into your television do you get image on your tv? this would suggest that indeed there is a problem with the viewfinder and most likely a wire is cut or loose.
    If you have warranty please use it instead of trying to fix it yourself. On the other hand if you don't have warranty anymore we need to get you a service manual so you can get inside the camera without accidentally breaking anything on the process.
    By the way I didn't get a email message about your new message, I was just scrolling thought the problems and found that you had posted a comment, sorry for the delay.
  • Ekse Jun 12, 2008
    at this time I haven't been able to locate a public service manual for your product.
    You might be able to get one in your hands by contacting jvc support from this webpage form
    https://support.jvc.com/consumer/support...
    you can find a service center from
    http://maps.jvc.com/cAscList/
    please let me know if you have any further questions or anything else about this problem.
    The fact is, this seems to be a older product and locateing a service manual is very difficult if not impossible. I can contact JVC if you wish about this, or would you prefer todo it yourself?
  • Ekse Jun 12, 2008
    I have located a service manual and replacement parts for your product, you will not like the price thought.
    http://www.jvcservice.com/Service/JMdlPr...
    have a look there.
  • Ekse Jun 12, 2008
    here is a direct link to the service manual, also found on the list of parts
    http://www.jvcservice.com/Service/JPartI...
  • Ekse Jun 12, 2008
    Bad luck mate, the site has gone down for maintenance it seems, I hope it comes available again later. The manual is there the price was around 54usd.
    let me know if you need anything else. the service manual is pretty strate forward and has instructions on how to take it apart - check the wireing.
    let me know if you have any questions.
    Master:
    Sergeant:
  • 460 Answers
What is ur problem...?
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
The viewfinder on my gr-dvm5 isnt working it is just blank
Possible fault in the display unit , either the LCD drive has failed or a pico fuse has blown inside.
Remove battery and insert after sometime and see if there is any signs of picture coming in and then getting blank. If so the display processing is faulty.
It will be better to get the camcorder checked by the JVC service for an estimation to decide.
Aug 27, 2010 | JVC GR-DVM5 Mini DV Digital Camcorder
No image on LCD or viewfinder
viewfinder is off try to restore factory default and and im sure your problem is sort out
Apr 12, 2010 | JVC GR-D770 Camcorder
Nothing comes through to my viewfinder. Everything else seems to work fine.
If pictures are coming through to your screen, then the ribbon cable to the viewfinder has probably broken( they are quite brittle with age on this model). Can you see if it's broken when you hinge the viewfinder up? Replacement of the ribbon cable is the only viable option.
Feb 06, 2010 | JVC GR-DVL510 Mini DV Digital Camcorder
Camcorder model GR-90
Hi, your ccd is bad, good news, JVC will replace it for free. Go to www.jvc.com and select support, then select customer notification from the left side and then select ccd replacement program and follow the instructions, JVC had a lot of these go bad but has done an excelent job of correcting the problem
Aug 17, 2008 | JVC Cybercam GR-D90 Mini DV Digital...
Lens Cap Is On
ccd image sensor  your camcoder has broken
May 21, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Blur in viewfinder
Hi, i had the same problem and was suggested i visited the JVC website, this could be the manufacturers error reported on their web site. Failure of the CCD image sensor. Check JVC UK web site, support centre, if your camcorder has the problems listed, until 01/10/07 they will cover repairs. Mine now works ok. Hope this helps
Dec 30, 2006 | JVC GR-D60 Mini DV Digital Camcorder
No picture JVC GR-DF430US
Could easily be one of those picofuse which is a miniature fuse. Looks more like a small metal film resistor, except without the coloured bands. But SMD in Camcorders has now got so damm small, you cannot use a hot air tool without the risk of other parts moving, or loosing.. basically a Digital Camcorder has all the electronics of a PC mother board, shrunk into a small hand device, and also included a tape loading mechanism and a lens unit.. So I would suggest that you will get in touch with the JVC service agent, and see if they can extend the warranty, sometimes they will cover the Parts , but you will have to cover the labour..
Sep 17, 2005 | JVC GR-DF430US Mini DV Digital Camcorder
Video Cameras Logo
119 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
