Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor shuts off but green light stays on
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this? monitor works for an hour or so, then it shuts down for 15 mins.
There is no solution a chip is fried i just opened mine up it blows
Posted on May 22, 2009
    Problem Solver:
  • 6 Answers
I perhaps can. I would think inverter or ccfl's.
Posted on Jun 12, 2008
LCD monitor turns off
Nov 02, 2012 | Computers & Internet
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Flat screen monitor
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Jan 17, 2009 | Envision EN-7100e 17" Flat Panel LCD...
DONTKNOW WHAT TO DO
Your monitor need repair. Sounds like a power supply problem. The power supply is shutting down due to an overload.
Lou
Aug 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
634 people viewed this question
Alun Cox
