Question about EliteGroup P4VXASD (P4VXASD-R) Motherboard
I need help
Hello
my motherboard is P4VXASD ..intel pentium4 1.4GHZ/256/400/1.75v
first..i connect new hard drive ....that was know the hard drive ..and then i close the power and open ,there have appear Bios,checksum error and hang for long time.... i shut down the power and open again but there was nothing appear ...someone said to me i need to install floopy drive and start-up disk..but i don't have then because i can't buy for that cause of some cases ..so pls help me for this anyone who read this message ..pls and i'm really really thank for that ....
Driver for p4 vxasd
Posted on Jul 06, 2008
  • 871 Answers
You installed the new drive and dont make it the primary master. change the booting squence in the bios.
if the bios does not appear during startup. take out the new drive first. then install it again as a 2ndary slave.
Posted on Jun 12, 2008
  • 70 Answers
You need a floppy drive and a startup disk, because that is the only thing that the motherboard will read (i think) in that kind of problem. But ok if you really dont have that items, try this disconnect all the motherboard connectors, like IDE, SATA, & POWERSUPPLY, also temporarily remove all hardware cards connected on motherboard like, Modem, LAN, Video Card, etc. Then you also need to remove the CMOS Battery, its like a silver coin on your motherboard, and also the Processor & Memory. Simple NO DEVICE MUST BE CONNECTED on your motherboard. Then just let your motherboard rest for alteast 1hr or 2hrs. After that, then assemble again your Computer. Be sure you know how to put it back together.
-mrsolution
My monitor does not work since i install a graphic card,what should i do i cant see anything on monitior
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Jul 08, 2012 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
My new asrock p43de3 motherboard dont wana start and i dont know why please help
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 16, 2011 | Asrock P43DE3 LGA 775 Intel P43 ATX Intel...
P4VXASD how to plug in the power button
Do you have a Manual for this motherboard? Have you tried downloading one from the motherboard manufacturer's website.
They are usually pretty straightforward in explaining how to connect the power, power LED, Hard drive LED, Speakers. All usually plug in to one area of the board SB
May 20, 2010 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
My P4VXASD motherboard has a burned (very small) diode is is rep
Does your PC work well as it is? If so, I would not even try to have this repaired. The cost is too great and almost no one that I know will attempt an on-board solder repair.
Rich
Dec 15, 2009 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Hello
As i search about what you need to know about the 500GB SATA HDD can support in MOBO, i say YES!
865GBF Desktop Board
Two Serial ATA connectors
If there any question just add comments.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Intel D865GBF Motherboard
Intel Motherboard Problem
Hello ezinash ,
replace ur hard disk with a new one and than try
Jul 21, 2008 | Intel Motherboard
Help me pls
First you need to have a Floppy Drive installed on you computer, then Second you need a stat-up disk.
You also need to download the BIOS File Update on this link
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?
CategoryID=1&Typeid=2&detailid=59&DetailName=BIOS&DetailDesc=P4VXASD(V1.3)
&MenuID=39&LanID=9
Then you also need to download an AMI FLASH Utility Software to upload the BIOS FILE Update on your motherboard, you can use the link stated on that link above.
If this procedure solves your problem, please spare a little time to rate my solution.
-mrsolution
Jun 12, 2008 | Intel Motherboard
Help me
Is your board completely dead?
It should at least beep without memory installed. It should start CPU fan.
1. If your board is completely dead, check your power supply.
2. Visually inspect caps around your CPU. If you see any bubbled tops, you need to replace those caps.
3. You also might have a bad CPU.
4. Try to remove a backup battery and wait for a couple of minutes before reinstalling it back. It might reset your CMOS and BIOS
Good luck!!!
Jun 11, 2008 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
EliteGroup P4VXASD (P4VXASD-R) Motherboard Logo
172 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
