Question about Sharp Televison & Video
The tv has blue green and red lines in it - Sharp Televison & Video
  • samanthaross Jun 12, 2008
    someone said that the lead was broke and it could not be fixed
  • samanthaross Jun 13, 2008
    lc-42d64u sharp aquos is the brand
  • Sharp Master
  • 8,617 Answers
Can you post a picture of what the picture looks like?
Posted on Jun 12, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jun 12, 2008
    are you refering to the HV lead that goes from the slplitter into the CRT? If so you can repair that even if its sealed in the CRT CRTs are available used. Whats the model number of your set. But the HV lead shouldnt cause the symptoms your describing as a broken lead would cause electrical arching, not video distortion
  • Sonny Berry
    A broken lead should not cause those symptons. Whats the model number of your set? And broken HV leads are repairable.
  • Sonny Berry
    Sonny Berry Jun 13, 2008
    I wasnt aware that it was an LCD television. It would cost more to repair than to buy a new set.
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Adjustments on the RED, Green and Blue
you ahve to line the red and bule up with the green since the green is imobile
Oct 10, 2008 | Sony KP-51WS500 51" Rear Projection...
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
