Question about Kenwood KDC-516S CD Player
Cd player wont eject
So i have the kdc 516s cd player.. bought it off craigslist and everything works... lights.. buttons and everything.. but when i try to eject the cd (that was already inside the cd player when i bought it) it would eject.. and i dont know what to do..
can someone help?
  • dbau Jun 12, 2008
    i meant to say
    so i have the kdc 516s cd player.. bought it off craigslist and
    it WOULDN'T eject.. and i dont know what to do..
    can someone help?
    President:
  • 624 Answers
You can try pressing the reset button on the display, it is a very small indented button that you need a paperclip or something smaill like that to press it. This is the only user action that can be done.
Do you hear the cd mech making any noise at all (gears trying to turn, motor running)? if not, you may have a supply voltage out for the cd mech, bad ribbon cable, defective loading motor, or one of several other possibilities.
If you hear something trying to happen, it will most likely be a jammed up mech. There is a plastic piece inside the mech that is very difficult to get to that may need to be replaced or at least re-aligned.
If you are not familiar with these type of mechs, you really should not try and fix it, you will most times cause more damage to it.
sorry there was not better news for you. let me know if resettng helps or if you feel you can fix it yourself, I would be glad to offer more help.
Posted on Jun 18, 2008
  • seansmith52 Dec 04, 2010
    remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
The back light won't turn on and the volume is turned all the way up but the buttons won't work for me to turn it down. I had to take the whole thing out
Assuming your deck is a kdc 516s the flexible cable that goes from the face to the main motherboard is probably bad. If you are not good at desoldering and soldering. , I would suggest you have it replaced by a professional.
May 06, 2012 | Kenwood KDC-516S CD Player
My radio gets power but wont turn on
the radio may have a bad flexible cable. (goes from the face to the main motherboard).
Feb 09, 2011 | Kenwood KDC-516S CD Player
What is the unlock code for my kenwood kdc-516s car stereo?
to get the key you will need to take it to a kenwood repaierer as all units have different codes
Jun 25, 2010 | Kenwood KDC-516S CD Player
What is my unlock code for my Kenwood KDC-516S car stereo?
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Unable to remove faceplate or eject cd on kenwood
Jan 17, 2010 | Kenwood KDC-516S CD Player
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
What is the dark blue wire comming from my kenwood kdc-516s deck?
It is probably the remote amp wire or power antenna wire. you can check by hooking up a volt meter set on 12 volts DC and see if there is power when you turn on the unit
Oct 03, 2009 | Kenwood KDC-516S CD Player
Kdc 5016 time set
Hi go to kenwood site and download the manual for a KDC-516S (it s the same setup as 5016.
or Just press the menu (3 secs) and use the am and fm buttons to nav to the time adjust. then use the arrow keys to change AND SET the correct time.finish by pressing the menu again.
boseman...
Sep 12, 2008 | Kenwood KDC-MP232 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Can not find the code for my kenwood kdc-516s
Same problem, different rig. Bought a bronco with a Kenwood KDC 516s in it, Guy had put a new optima battery in it CODE_ _ _ _  appeared and he has no clue what the "code" is. I have no "remote" and no desire to buy a "remote" for a #$%@ car stereo. Is there any way for me to re-set the code w/out the expense of a remote or a fee from a tech?? the musically challenged, Brew
P.S. The owners manual under the "accessory" section  mentions the KDC x617/v-6017 remotes but fails to mention a remote for the 516s??
Jun 19, 2008 | Kenwood KDC-516S CD Player
Kenwood KDC-516S CD Player Logo
170 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
