Back to:
Tags:
Dacor PCS130 Preference Electric Single Oven
Dacor ECPS130 fan won't shut off
posted by Gimungus on Jun 12, 2008
I have a Dacor ECPS130 oven installed in a kitchen island. Liquid was spilled down the front of the oven, the display went crazy and then the oven went into self-cleaning mode, the door locked an I couldn't stop it.  I shut off power to the oven and the door unlocked.  I removed the front panel and cleaned off the membrane panel and mopped up all the liquid.  After reinstalling the panel and restoring power the panel functions fine, all the controls react properly except that the fan runs continuously and I can't get it to stop.  I've tried hitting the high-limit reset switch with no luck.  I ran a resistance test across the switch and it is open. Any advice would be greatly appreciated or even directions to a schematic.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Ovens problems?
Dacor PCS130 Preference Electric Single...
I am very dissapointed to report that my Dacor PCS130 wall...
Did you ever find a resolution on the Dacor F1 beeping? ...
Te inner glass broke - how do I replace it? Is it easy to...
My Dacor PCS130 lights will not work. It appears that the...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
