Question about Dometic Rooftop RV Air Conditioner
Fridge not cooling
Dometic rc1600 3way fridge not cooling back side feels hot do u think it needs more NH3 coolent/refrigerent
If you look in the outside compartment do you see a yellowish powder? If you do, or if you smell amonia probably the cooling unit has leaked the coolant. It does not help to add coolant, it will just leak out again quickly. You will need a new fridge or to have the cooling unit replaced. If that is the problem, Dometic has a recall on some models for leaks and will pay for a new cooling unit.
Posted on Jun 16, 2008
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
3.5cu camper dometic refrigerator. how long does it take to cool and should i hear it turn on? is it normal for the heating elements on the back (leu) to get hot?
If the element is hot thats what its supposed to do...if the whole back side is hot its a problem,as far as how long you should feel some cold in at least one corner of the freezer in an hour or less...On a hot day mine takes about 3 hours to get in the forties in the friodge and zero in the freezer.
Aug 09, 2010 | Dometic Refrigerators
Not cooling on 120 V0lts
NDR 1062, cools with gas but will not switch over to Ac . If i turn off lp, check light comes on and doesn't cool
Jun 22, 2009 | Dometic NDR 1062 Refrigerator
We have a Dometic RM2601 Fridge. won't
Check around the burner area for a yellow film the ammonia has leaked out
Jun 12, 2009 | Dometic RM2620 Refrigerator
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Dometic Rooftop RV Air Conditioner Logo
221 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
